Miss, well it feels like
  • Hugger
    • Apr 2011
    • 4
    I bought a GA with 3400 in it a few months ago with blown head gaskets, i did a 3500 top swap and now im having driveability problems. I have good compression and the timing is in the correct order, but i think it might be in the fuel system. I can rev the car up to about 3500-4k rpm and that is as high as it goes. The intake sounds really loud when this happens. So, should I ohm the injectors? noid the connectors? anyone else run into this problem by chance? any help is appreciated
  • 95SleeperAcheiva
    ArtofOlivia"PocketRocket"
    • Jun 2006
    • 694
    temporarily open your exhaust. Either drop the front pipe off the manifold or cut a slit in it with a saws all if you have a mig welder to weld the cut afterwards. Then start it a see if she'll rev past.
    Oh before that, not to call you on this but, it's not the rev limiter is it? :P
    I suspect a clogged exhaust.
    Unless you have an exhaust pressure gauge, they usually screw in where an 02 sensor goes, should be 2-5 lbs.
    • 95SleeperAcheiva
      • Jun 2006
      • 694
      oh, IF it is a clogged converter, something clogged it. After the converter repair check for bad coolant temp sensor, thermostat stuck open, bad MAP/MAF, etc and change your plugs, again, they maybe fouled.
      run her a bit, pull a plug and read it. if it's black, your rich. now find out why or you will eat the new converter.
        • 9190
        That was my first thought as well... are you trying to rev is higher than that in park? If so, its not going to happen.
        Brad via Tapatalk
