Ok guys so I have a p0336 code, crank position sensor A. Which sensor is it, the 24x or 7x? Thanks guys.
3400 with P0336
To help in the future, the car won't run with a bad 7x sensor or wire but will with a bad 24x sensor or wire. 24x is just for SFI below 2k rpm, I believe.
Sent from my HTC One X using Tapatalk 2-60v6's 2nd Jon M.
Ok so I ended up replacing the 24x sensor and now the car is running on 4 or 5 cylinders. There was a flashing check engine light but it went away after I restarted the car. It's all though out the rev range. ICM maybe? It has less thank 5k on new plugs and wires.2003 Grand Am GT Ram Air
-Magnaflow High Flow Cat
-Flowmaster 80
-Brembo Brakes
Crank relearn. I think I could be wrong but that's my bet right now Or the other sensor is bad too. Remember it controls SFI below 2000 rpm. Any other codes now. You had a CEL. Flashing you should have something in the history nowLast edited by unchained01; 06-21-2012, 10:44 PM.
