Part throttle bog in 3500 Fiero (OBD1)
  • LZeppelin513
    • 225
    I fouled my plugs in the first few test drives after my swap. Bad plugs could cause some of your drivability issues.
    • caffeine
      • Jan 2012
      • 1489
      I was going to change the plugs anyway, but I've already driven several thousand kms with the swap and the problem only appeared recently (I lowered the car a couple of weeks ago, so the ride got a bit bumpier)
      The only wiring I haven't tugged on with the engine running is the interior wiring. Engine bay wiring seems to check out.
      Positive battery cable is tight as well. And sometimes, like yesterday, the issue will come and go without moving the car while idling.
      '86 Fiero, 3500, 4-speed
      • caffeine
        • Jan 2012
        • 1489
        Ok so I replaced the crank sensor wiring with wiring straight out of a wrecker; no noticeable change. This morning when it stalled after turning a corner I noticed the check engine light and the shift light were flickering a little with the key left in the on position. It wouldn't start until I turned the key back to off first.
        ECM?? Or maybe I'm also thinking the G1 chip adapter might be loose.
          It couldn't hurt to check the chip/adapter. I imagine if the ecm were bad the car would do it all the time or not run at all, although the shifter light and the ses light both flickering is starting to make me wonder about your interior wiring. You do have to modify that to run the ecm you are running, right?
          • caffeine
            • Jan 2012
            • 1489
            Most of the interior wiring was repinning the stock wires. I think there are 3 or 4 splices in the interior for vss, some injector wire, and maybe one or two more
            I suppose some of the pins could be loose too though.
            Unfortunately I won't have time to check out the interior wiring until Sunday or Monday.
            • caffeine
              • Jan 2012
              • 1489
              #21
              Ok so I tools the center console off and the g1 adapter was crooked in its socket. I'm not using a proper ECM tray for it so I'm guessing the center console was pressing against it esp during hard cornering and over bumps.
              I've been driving the past couple of days with the console removed and haven't had any issues. I'll probably just modify my ECM tray some more to get it sitting nicely.
              • caffeine
                • Jan 2012
                • 1489
                #22
                Modified my ECM tray some more and it now sits nicely. Actually wasn't hard to make the stock ECM tray work with the 7730 but I should have modified it more from the start...
                  Glad it was an easy fix and worked out
