definitive rocker torque spec 03 3.1 Malibu
  • jim68127
    • Jul 2012
    • 12
    Just about ready to put the semi swapped motor back into the car. Used the bottom end
    from a 98 motor with only 70,000 miles and original top end from car. Had the original heads hot tanked and cleaned up. Now I need the torque specs for the 8mm rocker studs. I have read a variety of specs: 189 inch lbs, 168 inch lbs, and 124 inch lbs with 30 degrees. I have an older book that goes up to 2000 and states 14 ft lbs (168 inch lbs) plus 30 degrees but I don't know if 2000 3.1s had the 10mm or 8mm studs. So for an 03 with 8mm studs and the blocks which is the correct spec?
    Thanks in advance.
    • 9179
    If you go to the articles section (click on the HOME button at the top), then goto pushrod and maintenance, you should find the specs listed either with a TSB (that may be for manifolds only, not rockers) or the actual engine specs (use the specs for a 3400).
    Brad via Tapatalk
