Timing cover gasket-what else?
  • talon2swords
    • Dec 2007
    • 132
    Hello,
    I'm working on one of my old beaters, a 97 Lumina w/ 3.1l. It needs a new timing cover gasket. So I have the cover off.
    Just asking for opinions. What else should I replace while I'm in there? The timing chaining has some slack on the left side, I guess that is normal, it is tight on the right side.
    I think I am going to replace the camshaft sensor, since I've been getting an intermittent code for that. I don't know if I should replace the crankshaft sensor, guess I will if it is cheap part.
    Thanks for advice.
    Oh yeah, car has about 128K on the odometer.
Name:	97 timing cov.JPG
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    I'd replace that chain and the sprockets while its apart. That is one nasty looking work space lol
    • talon2swords
      • Dec 2007
      • 132
      Nasty, drippy and sticky engine, but the piece O crap still runs. I luv it.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        That almost sounds like a STD
        • cavalier3400z
          • Jul 2012
          • 29
          Change the timing chain
            Don't buy a cheap replacement one either, it will fail quicker than the stock setup. If you want to stretch the life of the car its worth getting the GM setup that Ben sells on the WOT store.
            • geoffinbc
              Iron Head Enthusiast
              • 5831
              And remember to replace the set. Putting a new chain on old gears is just asking for premature wear.
