Not able to keep my cool
  • LeftVentricle
    Right aorta
    • Oct 2005
    • 506
    Howdy, y'all. Long time no post. I've been out of the 60V6 game for a long time, but I'm back in it now.
    I acquired a 1996 Buick Century wagon quite recently—this past Monday, February 25th, to be precise. The price was decent ($1500, book is over two grand) and the body and interior are in good shape. It drove well from Ontario, CA, back to Las Vegas, and got 26 mpg. Not what I was expecting for a 3100 V6 in a relatively light car, but still pretty good. Like any old car, it needs some lovin', some maintenance that seems to have been deferred, like brakes, shocks, struts, oil change, transmission service. You know, the usual stuff people mostly ignore. All in all though, a pretty nice deal.
    Fast forward to last night. It popped the upper radiator hose. Luckily it happened about two blocks from home. Unfortunately, I had to push it those two blocks, and, not kidding, nearly died from the exertion. Was dizzy, light-headed, tingling in the extremities, all that. Today I put on both rad hoses and a new cap, and said "fuck that" to the thermostat because of its location and the things that seem to need moving to get to it. I couldn't bleed the system, so I took it to a shop to have them do it. Said shop tried to take me to the cleaners. I was given a prognosis of a blown head gasket (despite the lack of telltale white smoke from the exhaust), and told that it would be more cost-effective to put a new engine in, for a nominal fee of course. I politely told them to give me back my car and left.
    A couple miles later, the temperature gauge was pegged and the heater was blowing cold. I had the car towed back to my house courtesy of a friend's roadside assistance. He's something of a mechanic as well, and after fucking around with it, he says it needs a thermostat and maybe a radiator. This is based on the fact that the temp gauge is pegged, the engine is hot, both hoses are warm but not hot, and the radiator is ice cold. It's probably clogged, and/or the thermostat is stuck. Does that sound right?
    Here's a picture of it, if that helps.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Yup sounds about right. The rad should be the same temp as the engine. At full operating temp there is no way you could rest a bare hand on it. Do the stat first. Just for diagnostic sake once you get it out if there is no obvious problems then put it in a pot of water and bring it to a boil on the stove. It should open just before the water begins to boil.
    • Purple pit
      • Oct 2012
      • 718
      The T stat housing has a notch cut out of it so you don't have to take the lower bolt out. Just take off the upper blot and get the lower bolt loose enough to take the housing off.
      Grand Prix trans with 3.33FDR
      • LeftVentricle
        Right aorta
        • Oct 2005
        • 506
        That's great to know! I was thinking I would have to pull the throttle body to get to it.
        • TGP37
          Shadetree Engineer
          • Jul 2011
          • 1027
          Just having too low a coolant level can make the symptoms you speak of.
          I would refill the coolant in the rad neck (not over flow tank) and start the car cold with rad cap off. Blip throttle a few times to see if more coolant is needed.
          Parking the car facing up on an incline can help bleed it.
          What you want to check is the coolant line from the rad neck to the over flow tank. Often times they can leak or crack where it lets coolant out of the rad when hot, but puts air back in when cooling down. Make sure that is sealed up well. What you want is coolant spilling into the over flow as the coolant gets hot (expanding). If there are no leaks, it will draw coolant back in when cooling (contracting). Even a small crack in the plastic nipple can introduce air. Eventually compromising the coolants ability to circulate from the air pockets halting proper flow. Which is why the heater is ICE cold but the temp gauge says hot.
          • LeftVentricle
            Right aorta
            • Oct 2005
            • 506
            New thermostat in, now it won't start. It started and ran before the repair. While the TB was off, I cleaned it and the MAF with TB cleaner and MAF cleaner on the appropriate side. Would that ruin the MAF and cause a no start?
            EDIT: Pulled the spark plugs on the front bank, they're wet with coolant. 80-90-110 compression.
            • TGP37
              Shadetree Engineer
              • Jul 2011
              • 1027
              History of overheating and now coolant soaked spark plugs. Could very well be a blown head gasket. But it might also be a leaking coolant line above the plugs, or the coolant was spilled when filling/bleeding?
              My best guess is warped cylinder heads with cracked/dead head gaskets.
              MAF cleaner is fine but I can't tell you what TB Cleaner would do to the sensors in the MAF. Most cars will run just fine with the MAF unplugged.
              • cavalier3400z
                • Jul 2012
                • 29
                Probably just the head gasket. Pull the head and check it with a flat edge. You can also use a camera probe and see where it blew. As long as it wasn't severely overheated the head should not be warped.
                Sent from my iPad using Tapatalk HD
                • LeftVentricle
                  Right aorta
                  • Oct 2005
                  • 506
                  Yeah, I'm looking at a head job for sure. Gonna take a while, assuming I even have the right tools. I know I'm lacking at least a torque wrench for reassembly. Is there anything special I will need for tearing down the top end?
                  • cavalier3400z
                    • Jul 2012
                    • 29
                    I believe a 8,10,13,15mm sockets and ratchets. That should be all and a torque wrench. Harbor freight sells decent ones for 10-$20, so does Walmart. Head gasket is a simple job. You will also need head bolts and new intake gaskets. You should be able to get it all for under $100. Changing head gaskets on these cars are so easy. You can probably get it done in 2 hours if you are comfortable working on cars. You should also get a scuff pad or similar and a razor blade to take the old gaskets off. Just clean the surfaces good and reassemble.
                    Estimate:
                    Take the top intake off - 10 bolts.
                    Take lower intake off- 4 bolts
                    Take thermostat tube off- 2bolts
                    Valve cover - 2 bolts
                    Rocker arms -12 bolts
                    Head bolts - 8 bolts
                    • TGP37
                      Shadetree Engineer
                      • Jul 2011
                      • 1027
                      It is more time then special tools. Remember to catch the little o-ring that flies out if you disconnect the fuel lines at the rail. I try to lift and hang the entire LIM with the fuel rails attached.
                      The P/S Pump can be unbolted through the pulley holes....3 bolts....set to the side with hoses attached.
                      You might need to replace spark plugs and cables due to overheating. Especially old cables as they often break when pulling off at the boot.
                      When you remove the spark plugs, keep them in order so you can inspect them by cylinder if needed. And DO NOT over torque any manifold cause the LIM will leak and the UIM will crack if too tight.
                      You also need Black RTV for the LIM valley.
                      Drain coolant from the block or the coolant in the heads will dump coolant into the crankcase when pulling them.
                      • unchained01
                        • Jan 2011
                        • 388
                        If it were mine I would have the heads tested and resurfaced And use new head bolts as they are T.T.Y .
                        • TGP37
                          Shadetree Engineer
                          • Jul 2011
                          • 1027
                          With the water pump spinning backwards, the heads may have been subjected to serious heat. Depends if a vacuum was created or not. Basically pulling whatever coolant possible out of the block while the t-stat prevents more coming in.
                          I would at least check the heads. Would suck to put them back on and have them leak and ruin all that work, gaskets.
                            QFT.
                            ~$80 for cleaning and testing is less than another head gasket set anyways, and every aluminum head I've taken in has had to have some degree of resurfacing to get a perfectly flat surface. I think of it as insurance and piece of mind.
                            That was another guy in the DOHC section with a Z34.
                            • TGP37
                              Shadetree Engineer
                              • Jul 2011
                              • 1027
                              QFT.
                              Ah wow, twice in one day!
                              I need a /knock in head smilie, lol.
