92 Lumina 3.1 balancer removal?
  • ledopmi
    • Mar 2013
    • 3
    The outer ring fell off my balancer. I removed the center bolt but there is no room to use the puller to remove the balancer. Is there a special tool for this or do I have to remove the entire engine?
    Thanks
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Buy or rent a balancer puller. It takes about 2 minutes to remove it. Most tools also double as an installer.
    • cavalier3400z
      • Jul 2012
      • 29
      You will probably need a balancer puller and an impact gun to remove it.
      • ledopmi
        • Mar 2013
        • 3
        I have a puller but there is no room for it. The balancer is too close to the inner fender
        • cavalier3400z
          • Jul 2012
          • 29
          Lower the engine some then.
          Sent from my iPad using Tapatalk HD
          • geoffinbc
            • 5831
            I have also herd of people cutting access holes in the fender and then using plastic body plugs after the job is done.
            • unchained01
              • Jan 2011
              • 388
              Easier to take the strut loose at the top and lower the cradle on that side Of course take the motor mount out
              • ledopmi
                • Mar 2013
                • 3
                I got it buy removing front mounts, tilting the engine forward and installing the mounts with the extra hole at the bottom to hold the engine there. (Like changing spark plugs) I also had to remove two bolts for the steel heater hose and move it out of the way and remove the plastic fender skirt.
