Idk what the problem could be all my sensors are new I found my cam and crank signal wire grounding out when not connected to any thing I jus don't get it when I start to crank I have slight pulse then it jus goes away and comes back hit and miss and my rpm readings and intermitent
95 3.4 camaro losing injector pulse while cranking
Tags: None
It sounds to me like you might have a bad sensor out of the box. It has happened to me. How are you testing for signal?
I have a '94 Camaro 3.4L, so I can at least look at what you are looking at too!
I'm using a probe that works like a noir light and my cam crank signal wire the pink and black wire would be grounded even when it was disconnected from the pcm
