2002 Montans 3.4 engine swap
  • mikrness01
    • Mar 2014
    • 9
    I have a 2002 Pontiac Montana with a bad engine. I have access to al 2004 Chevy Venture with a good engine. Will the 2004 engine interchange for my 2002 Montana?
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Those years should be, with some common swapping of exterior components.
    • mikrness01
      • Mar 2014
      • 9
      2004 to 2002 3.4L swap
      [QUOTE=1988GTU;468911]Those years should be, with some common swapping of exterior components.[/QUOTE
      Can find anything that says it will fit. Really need to know if it will and what if anything has to be changed.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        brackets may need swapping depending the config, but really if you want a direct swap in and swap out then you will find that only staying with your year make model specific engine will only be a guarantee fit.
          Engine is a direct swap... but as 1988GTU stated the brackets and mounts that are bolted to the engine may differ due to the platform differences.
          It helps us to know what you consider interchangeable. Simple side by side comparison between the two would answer your questions of what you would need to swap over.
          • mikrness01
            • Mar 2014
            • 9
            I read the Family tree for these enginee. They change the pickup for the camshaft sensor and I don't know about the crankshaft sensor. The engine needs both thing to run and be in time.
            • caffeine
              • Jan 2012
              • 1489
              If the cam sensor is different simply unbolt the one from your old engine and install it on the new one... Crank sensor is the same on all 3400s except for the Chineese-made Equinox engines.
              '86 Fiero, 3500, 4-speed
                And despite the trigger on the cam looking different it still works just fine. Just ask the 98 Transport I put a 3500 cam in years ago that's been running just fine since.
                  I have an 04 engine cam sensor and a 2000 style cam running on my 97 ECU... It doesn't matter.
                  • mikrness01
                    • Mar 2014
                    • 9
                    04 TO 02 Engine Swap
                    Thanks for your insight. I bought this 04 for $300.00. But all of the interchange manuals do not show it will work. Only makes sense to me that if you change the right components that it should work. Will probably change the intake over from my 02 engine, that way the intake gaskets are new. The van is in good shape for 160 K miles.
                    This is the second one that I have had. The fist one was a 97 and it broke a cam. Had a engine put in that one too.
                    • mikrness01
                      • Mar 2014
                      • 9
                      Ok, changed engines. Used injection, sensors, intake, off 2002. New intake gaskets. Started and ran 15 seconds than died. Won't start. Has 53 lbs fuel pressure at rail, good spark, will incarnate cleaner. Checked voltage to CPS and Cam sensor only has 5 volts. Help please!!
                      Sent from my ADR6350 using Tapatalk 2
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        is it getting spark?
                        • mikrness01
                          • Mar 2014
                          • 9
                          Yes, good spark. It seems that it a fuel problem.
                          • mikrness01
                            • Mar 2014
                            • 9
                            Will run if you spray some carve cleaner in it.
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              Check your fuses and injectors circuits.
                              What's the fp at the rail at now? Do the inhectors spray while cranking?
                              Tach move around while cranking engine?
                              Codes?
