heater fan replacement & brake perportioning
  • englundjd
    • Jan 2013
    • 31
    Alright so my heater fan or whatever its called (the interior fan that blows air out the vents) took a dump, its making some pretty interesting noises. I bought a replacement but I cant find the fan under the dash. Any help on how to get the old one out and new one in?
    Also have a braking issue, my brake petal seems a tad soft and my drivers side rear brake is trying a lot harder then the rest as I've locked it up a few times trying to stop at stop signs on gravel
    91' Cavalier z24 A3: cai, muffler (no fart can)
    94' Camaro z28 A4: turbo build commencing
    94' Firebird Formula A4: LT1 355ci, cam, stall, gears, bolt ons, tune
    98' Monte Carlo Z34 A4: stock
    07' Impala LT A4: stock
    • 9175
    Blower motor should be accessible from the passenger side of the engine bay, up against the firewall. Not sure what kind of car you have, but just do a google search for your car and "blower motor", and it should show you where to look.
    • Guest
      What's this have to do with a pushrod 60 degree V6? *confused*
        • 9175
        Quit being an ass Chris...
        • englundjd
          • Jan 2013
          • 31
          still needing help with the brakes... any ideas guys?
          • carbon
            Procrastinator
            • 388
            Yeah... do a brake job.
            Drums in the rear? Adjusted correctly?
            Check for seized pistons and/or guide pins in disc brakes...
            Bleed the whole thing lately? Air in the system will cause a soft pedal... so can worn rubber flex lines.
            You listed 3 cars in your signature and specified none in your post...
            - Ben
            • englundjd
              • Jan 2013
              • 31
              thanks for the ideas... I recently went over the front brakes and replaced the pads which helped a little...
              The only 60* v6 car in my sig is the cavalier. the monte is a z34 with a 3800 which is 90* and the camaro is an lt1 v8
              • carbon
                Procrastinator
                • 388
                That never stops anyone from talkin' 'bout the others... LOL.
                I recently replaced a hub on my minivan and found the guide pins were dry and the pads are nearly gone... makes a difference.
                - Ben
