I've got a 3.1L in a '93 Trans Sport. If the oil level is half way down the cross hatch area on the dipstick and I turn left the oil pressure drops to 0 (zero). It doesn't do this when the oil is at the full mark. I've never had or heard of any vehicle doing this. The pressure really is dropping, because if the pressure is down long enough the valves start tapping. What is going on?
Oil pressure drops
Possibly a clogged pickup screen? Weak oil pump? What is the pressure under normal circumstances?\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
m retta used to act wierd when i turned most of the time it ment i needed more oil
or it needed to be changed really bad and was losing viscosityI Like V660s
Does Chevy make beer
~Jayme~
The pressure stays right around the fourth line. (No numbers on the gauge) A little over when cold and a little below when warm.Originally posted by DEI37What is the pressure under normal circumstances?
It doesn't fluctuate at all under straight line driving, slowing, accelerating and turning right. It doesn't matter if the oil is new or old. If its a little low (like 1/2 a quart) it will drop to zero when turning left.Originally posted by TheProfessormost of the time it ment i needed more oil
Could the pickup screen tube be loose? But why does it do this only when turning left?\'87 Camaro, 2.8L (rebuilt), TH700R4, Dynomax Super Turbo cat back, CATCO high flow cat, K&N air filters, 180 degree thermostat, 3.42 rear end
\'93 Pontiac Trans Sport, 3.1L TBI, K&N air filter, 212000 miles
I wonder if you have a hole in the pickup? When you turn left the oil sloshes to one side un covering the hole.
Could be a possibility. I suggest you drop the pan.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
