Pulling lifters - does rotation direction matter
  • BoringLumina
    • Oct 2004
    • 32
    OK,
    I was thinking about pulling the lifters and giving them a good cleaning since I got water in the oil. The question is these roller lifters have been going 190,000 miles in one direction, will it matter if I put them in "Backward"? I will make sure the lifter stays matched to the cylinder and valve but I will not be able to pull and clean them if direction matters.
    Thanks
    Boring Lumina is a White 4-Door with 191,000 miles on a 1995 3100 V6. No mods and only minor repairs so far (Hoping the repairs stay to a minimum) Why yes, I am an
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Unless the valvetrain looks messy I would leave them. I cannot remember off the top of my head but arent the guides for the lifter D shaped so you cannot put them in backwards?
    • v6h.o.
      • 1418
      No, the lifters could go in either way. they are just flat on each side for the anti rotation bars. Wont matter anyways. Roller lifters do not wear to specific camshaft lobes. This is why you can reuse Lifters on a Roller cam.
      Colin
      • geoffinbc
        • 5831
        Yea I guess you cant wish for everything
        Ohwell Colin is right roller lifter can be reused. I would try your best to keep them where they are. Just do one at a time and use a scribe to mark which side points at the cam. Be sure to scribe on an insignificant part of the lifter.
          • 9191
          Or use a Sharpie to mark it. Just make sure not to clean off the mark!
          • geoffinbc
            • 5831
            Which is why I suggested the scribe. Solvent will most likely remove the sharpie mark
