Sudden: high idle and high rev. shifts
  • TheDirtyBen
    • Mar 2004
    • 130
    okay, this just started. engine idles between 1200-1500 RPM. also, transmission doesn't shift normally. engine must rev upto around 3000 RPM or i have to completely let off the gas pedal to get it to shift gears. found one vacuum leak and fixed it. no other vac. leaks. IAC is clean.
    Both issues started simultaneously tuesday evening. i'm at a loss.
    1994 Oldsmobile Achieva (2002 3100 SFI)
    Homemade ram-effect CAI
    K&N cylinder filter
    Poorboy Lowering Kit
    Front STB
  • ProjectMM
    • Mar 2004
    • 170
    RE: Sudden: high idle and high rev. shifts
    what year, make and modle?
    2002 Pontiac GrandAm GT1
    3400 v6
    TOG headers
    RSM 62MM T-body
    FFP underdrive pulley
    GRANATELLI MAF
    Ported upper intake
    MSD DIS 4 ignition box
    MSD Wires and coils (pending)
    Venom high flow fuel pump (pending)
    • TheDirtyBen
      • Mar 2004
      • 130
      94 olds achieva. 2002 3100 SFI
      K&N cylinder filter
      Front STB
      • imported_germ
        • Dec 2004
        • 197
        check your throttle posistion sensor and idle air control valve on the throttle body
        • TheDirtyBen
          • Mar 2004
          • 130
          how would either of these affect how the tranny is shifting?
          K&N cylinder filter
          Front STB
          • GPXSS
            • 588
            The trans shifts via MPH and TPS readings, it runs off a matrix between those two values. I have had my 3100 do some really strange crap when the TPS wiring was faulty, including the trans having a damn fit.
            I modify stuff
            • TheDirtyBen
              • Mar 2004
              • 130
              ok, went to auto zone. took off the IAC and TPS to be tested. turns out they didn't have a multimeter to test them. so, before i re-installed them, i hosed both down with brake parts cleaner (inside and out).
              idle is down to approx. 1100 RPM and trans shifts fine again.
              K&N cylinder filter
              Front STB
              • TheProfessor
                • 869
                get a vacuume gauge and do a intake manifold vacuume test
                you might have a intake gasket leak
                I Like V660s
                Does Chevy make beer
                ~Jayme~
                • TheDirtyBen
                  • Mar 2004
                  • 130
                  it's running ok now
                  K&N cylinder filter
                  Front STB
                  • TheProfessor
                    • 869
                    what was wrong with it
                    I Like V660s
                    ~Jayme~
                    • TheDirtyBen
                      • Mar 2004
                      • 130
                      <shrugs> didn't do anything other than what i said above.
                      K&N cylinder filter
                      Front STB
                      • TheProfessor
                        • 869
                        must have just been the sensors then
                        I Like V660s
                        ~Jayme~
