Which Intake Gasket?
  • razorz26
    • 5
    Hi, I have a 1996 beretta 3100 that needs a new lower intake gasket. NAPA has two parts listed- I ordered the 2nd design, but now im not sure that it was the right one.
    NAPA Gaskets Manifold Gasket Set (Intake)
    Usually ships in 24 hours. NGA
    MS16166 $ 54.99
    Plenum Chamber Gaskets are Included
    1st Design w/o Push Rod Guides on Intake Gasket
    MS16310 $ 52.99
    2nd Design w/ Push Rod Guides on Intake Gasket
    Does anyone know which of these is the right one for my car?
  • GPXSS
    • 588
    RE: Which Intake Gasket?
    if both of those numbers came back for your specific year/make/model then the 2nd option will fine.
    Since you are ordering gaskets then you'll need to pull the intake anyway and look in there. If you see metal pushrod guideplates on the heads, the 2nd design will not work and you'll have to go with the 1st.
    Usually the 2nd design is also for the larger port 3100/3400 which has different port spacing.. but thats the reason I wonder if it listed for your specific year, maybe they went back and updated all the older 3100 gaskets as well.
    I modify stuff
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      The second design *should* be for your 96. 95 was the chageover year.
      But in any case if you do end up having the old design it is not a problem. You can cut the plastic pushrod guides off of the gasket.
