I have a 2.8L engine in my Cav, and I found out the hard way that the #1 spark plug hole was stripped out. At this time I noticed valve tapping/sticking sounds, as well as a slight knock in the #1 cylinder. I am assuming that the knock was from the spark plug not being in the proper position because of the hole being stripped out. I am currently in the process of replacing the heads, and before I spend the money on the heads I wanted to ask if replacing the heads will cure the problem or if I'm screwed and have to replace the engine.
Will cylinder head replacement solve my problems?
1988 Chevrolet Cavalier Z24-2.8liter V6 MPFI/5speedTags: None
RE: Will cylinder head replacement solve my problems?
That knocking/tapping noise IS FROM the sparky not being tight enough. They make sounds like that where they are loose. Anyways you can repalce the head or you could use a thread insert....which the PROPER way to install the insert is to remove the head....Lorenzo
One of my friends who is a mechanic says that the thread inserts dont really work well, and that they will come out as well. So I will go ahead and replace the heads1988 Chevrolet Cavalier Z24-2.8liter V6 MPFI/5speed
eeh I'd say they work. If done properly I had it done a while back. seemed to last well over a 100,000miles....But alas cylinder heads are cheap enough for these motors.Lorenzo
i have one of the inserts on one of my heads and i pushing 10+ psi on the heads and not once had an issue
if the insert is done right it will not fail. the key is using some type of perminate thread sealer. i used JB Weld lol.
Interesting. Well since i already turned in my old heads as core, I'll still be buying the heads. Thanks for the info.1988 Chevrolet Cavalier Z24-2.8liter V6 MPFI/5speed
No, I just wanted to make sure that I would have no problems after I replaced my heads; also to make sure I wouldn't have to buy a new engine because of some problem I did not see. That was the main question.1988 Chevrolet Cavalier Z24-2.8liter V6 MPFI/5speed
