MAP Question
  • Bman
    • Jun 2004
    • 8
    MAP Question
    Hey,
    I just put my upper intake manifold on and tried to start my car. It started and then quit, I check for an engine code and (MAP/BARO low input curcuit). Does anyone have any ideas of what I can look for, I checked my wires and they were all in tack. I have a 99 grand prix with a 3100 SFI.
    Thanks,
    Brandon
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Is there a vacuum signal to the map sensor
    • George
      • Jan 2005
      • 11
      There is a vacuum line that connects the Map sensor to the manifold that is a little out of view because it is under the sensor. Is it hooked up and not leaking anywhere?
      • robby1870
        Squaddoosh
        • 584
        You might have broke the line or something. Pretty common thing when removing the plenum or doing rear plugs. I know Ive done it a couple of times. Once it was just a crack and really hard to track down.
        Robby Whitesell
        2006 Pontiac G6 GT
        1985 Toyota Pickup DLX
        • Bman
          • Jun 2004
          • 8
          Thanks for the info, I looked at everything and as I was putting things into place I noticed at the very base of the plug that one of the 3 wires had started to come apart. I think this is what may be wrong so I will have to solder it tomorrow.
          Thanks,
          Brandon
          • Bman
            • Jun 2004
            • 8
            That wasen't the problem, I tried it again and it still won't start, I have checked the connectors, hoses, wires, leaks, and still I can't find anything that is wrong?
            Is there a second fuse box on a 99 grand prix? If so where is it located at?
            Thanks,
            Brandon
            • imported_germ
              • Dec 2004
              • 197
              there should be 3 fuse boxes, IIRC.
              1 on the passenger side dash, by the door
              2 in the engine bay, 1 on passenger, 1 on driver side. both are located right by the fender and the strut tower.
              but none of them will have a fuse for your map i dont think
              replace the map and see if that helps.
              if you need one, i may have one laying around somewhere.
              • lumination
                • Feb 2005
                • 16
                engine probs
                if the car was hard to start before it died (had to use throttle) you might have the plug wires crossed when I swapped the 3100 in my 1997 lumina about a month ago and replaced the plugwires while I was at it well the coil was marked 1-6 and the intake is numbered also, plug and play right, WRONG. it was 180 out 1 was 2, 3 was 4, 5 was 6 it had me dumbfounded so hopefully that can help. JON
                Even though there is no replacement for displacement fuel mileage sure is sweet
                • Doubt_Incarnate
                  I still watch ROBOTECH!
                  • Jan 2005
                  • 1130
                  low input circut... so that means the power required for the sensor to vary isnt there? check for a short somewhere, maybe a wire got pinched during assembly, and is grounding out. but if you say it started up then died, then your sensor probably just crapped right then. once i went to shut my car off, and the cheap ass autozone icm died just as i touched the key, so the car died before i shut it down.
