torque spec needed - rear cam cover bolts
  • TurboSedan
    • Jun 2004
    • 218
    i'm pulling my 3.1 MPFI Turbo off of the engine stand today so i can replace the rear cam cover gasket and rear main seal.
    i can't find the torque spec for the three rear cam cover bolts in my Haynes manual or this site.
    also does the gasket use RTV? i was thinking probably using a thin layer of black RTV on both sides...
    TIA
    '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
    '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
    GM W-body Forums
  • TurboSedan
    • Jun 2004
    • 218
    ok i got the rear block face cleaned up and replaced the rear main seal. i have the rear cam cover surfaces all cleaned up and ready to go on....
    it's 3 small 10mm bolts and uses a cork gasket...does that mean no RTV or?
    i went to the library and looked through their Chilton, Haynes & Mitchell repair manuals and came up empty handed
    any help really appreciated, i need to get this done before i have to bolt the motor back up to the stand. it's hanging off the cherry picker right now.
    thanks
    GM W-body Forums
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Use 18LBS no RTV
      • TurboSedan
        • Jun 2004
        • 218
        thank you very much
        100th post woot! mmm BEEF JERKY
        GM W-body Forums
          • 9190
          Hey Geoff, where did you find that number? I looked all over and never found a number... We might want to add that to our torque specs.
          • geoffinbc
            • 5831
            based it on other similar bolt sizes
            • treeZ24
              i wanna go fast!
              • Mar 2004
              • 251
              ok i dont get it... in my gm service manual (89 2.8l Z24) it says nothing about a gasket being on the cam plug, but only to use sealer P/N 1052914
              any thoughts on this??
              next question is that the block i have on my workstand is a 1990 3.1L, did they change from not using a gasket in 89 to using one in 90????
              any P/N's or other info would be greatly appreciated
              got zap-straps?
              89 Z24
              13.886 @ 96.16 mph
              street trim - slicks
              • sharkey
                • Jun 2004
                • 2061
                last time i had the tranny out from behind a gen 1/2 660 i had to reseal the cam plug (they always leak). i tried to get a gasket and could get one, nobody lists it. its something that only comes in a gasket set. i always just use silicone.
                • treeZ24
                  i wanna go fast!
                  • Mar 2004
                  • 251
                  i have tonnes of gasket material sitting around, knowing this would it be a good idea to make a gasket IF i did not get a gasket set?
                  got zap-straps?
                  89 Z24
                  13.886 @ 96.16 mph
                  • geoffinbc
                    • 5831
                    You can just silicone it there is no need for a gasket if you dont have one.
                    • TurboSedan
                      • Jun 2004
                      • 218
                      i bought my rear cam cover gasket seperately from Checker for about $6. i'll find the part # tomarrow and post it. i used no sealer, just the gasket installed dry (which is cork with metal O-rings around the bolt holes).
                      GM W-body Forums
