***Need Help With One Hose Under My Plenum***
  • frank358fr
    • Feb 2005
    • 52
    Following you see three pictures. I would like to know how to disconect the hose (see red arrow on third picture) on that end.
    Thanks Frank
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    i cant see very well, but i think its the hose for the PCV mounted in the rear valve cover, it should just pull out.
    • jsgti18t
      • Mar 2005
      • 4
      yea, if you just pull up it should pop off if I remember correctly
      • frank358fr
        • Feb 2005
        • 52
        ok thanks all :P
        But I have a another problem, the old gasket of my plenum broke on this hole in red. How could I remove the tip on my plenum.
        Thanks Frank
          • 9191
          I've had to use a pick before to pry it out. It sometimes required to break it up and dig it out. Definately a pain sometimes.
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            Or drill it out. Something to just pick away at it. Its just plastic. Or even heating up a metal pick and putting it into the plastic then letting it harden to pull it out.
            • frank358fr
              • Feb 2005
              • 52
              ok thanks all
              Frank
