Strange Coolant
  • jacob_coulter
    • Mar 2005
    • 1
    Strange Coolant
    I have a 1986 Oldsmobile Cutlass Ciera with 2.8 V6 2 Bbl Carb. It has a strange coolant leak to it. It leaks about a pint a week. I put some UV dye in the coolant to help determine the leak, but I still can't see where it is coming from. Most all of the hoses have been replaced, and there appears to be no leaking at all around them. I suspected it was the water pump, since that is near where the coolant drips down, but that was replaced a few years ago, and there doesnt seem to be any sign it's leaking either. The rim of the pump has no coolant aoround it. Is there a detonation sensor that could be leaking, or something I'm not thinking of?
    Also, I'm a novice shade tree mechanic. How difficult a job is it to replace this water pump.
    Thanks again,
  • 94CuttySL
    • Aug 2004
    • 48
    Re: Strange Coolant
    Thanks again,
    Only thing that comes to mind is the intake gaskets. Could be internal.
    Mod List: http://www.cardomain.com/id/cutty94sl
    SOLD!!!!1994 Cutlass Supreme SL Coupe ~ 3100 V6 ~ 63,500 original miles
    • Doubt_Incarnate
      I still watch ROBOTECH!
      • Jan 2005
      • 1130
      doing that water pump should be about like doing any other one, take off 90% of the accesories, and then swap it out. just its fwd so your space to work is limited, unless you yank the motor. my car blew a head gasket but i dont think it had a coolant leak, just the gassed escaping into the coolant caused anumber of hoses to pop off. check for the core or "freeze" plugs, maybe one finally rotted through or something.
