Engine Coolant***Drain Out***
  • frank358fr
    • Feb 2005
    • 52
    Hi all,
    My engine coolant from my car(Lumina 1992 3.1L) drain out a little spot on the floor when I park the car. What is the problem. On my starter I say Engine Coolant when they have some Engine Coolant on the floor. What is the problem?
    Thanks Frank
  • korbendallas68
    • 3400swap.com •
    • 553
    Check any rubber hoses first. Then check to see if the heads are leaking (look on the side by the bottom and you might see it leaking from there).
    1995 Grand Am GT
    3400 V6 / 4T60-E / Engine Swap
    3400 Engine Swap Guide Version 2.5 is Available!
    www.3400swap.com
    • pepsi_coke
      • 288
      I know its not a DOHC .. but if I recall right, you ust removed your intake plenum, correct? Problem I first had after my first removal from coolant leak was from a heater hose to the throttle body.
      New member of 200,000 mile club as of May 16, 2005
