some q's from newbie
  • 854x4s15
    • Sep 2005
    • 24
    Hello all. I'm new to the site but not to the 60degree v6.
    my question is this; 1993 Corsica 3.1L. these engines have a coil pack instead of a distributor and Gm cheaped out when they changed this and kept using the same manifolds. So, where the distributor should be is that a threaded plug or a something similar to a frost plug? Any help or suggestions would be greatly appreciated as i have to get get this oil leak fixed, it keeps getting worst
    1985 GMC S-15 2.8L V6 Auto
    3\"body lift 2\"Suspension lift
    console shift
    delta tool box
    My toy
    1993 Chevrolet Corsica 3.1MPFI 3spAuto
    If it wasn\'t for the engine it\'d be long gone
    • 9188
    RE: some q
    http://www.60degreev6.com/index.php?...tor+oring+leak
    • 854x4s15
      • Sep 2005
      • 24
      Thanks that' just what i was looking for
      console shift
      delta tool box
      My toy
      • GndPrxRcr
        • Oct 2005
        • 18
        Change the O-ring and then take some permatex and seal the plug up. there is no need to get in there.
        1993 Pontiac Grand Prix
        1969 Chevrolet Camaro
        1988 GMC K2500
        • 854x4s15
          • Sep 2005
          • 24
          Ummmmmmm,no.
          console shift
          delta tool box
          My toy
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            If and when you change the O-ring install a smallblock chevy distributor base gasket. Extra insurance for teh future.
            The permatex trick does work. You can loosen and pull up the top of the drive gear and wash the area with brake clean squirt in some gasket maker and clamp it back down.
            • GndPrxRcr
              • Oct 2005
              • 18
              yep thats what i did to both my w-bodys but i used parts cleaner (same difference though) i did it like 6 years ago and i just checked it to verify, there's no leak on either. so yes it does work.
              1988 GMC K2500
              • 854x4s15
                • Sep 2005
                • 24
                Actually i'm planning on steam cleaning the engine(very carefully) before i start and using parts cleaner to clean up around there before i pull it out replace the o-ring, reinstall, then maybe forma gasket(high temp)???? Never really considered the Permatex though.
                console shift
                delta tool box
                My toy
                • Guest
                  You know, I've replaced the gasket only without all of these extra sealing steps and not a had a problem. The Distributer gasket can actually cause leakage, due to deterioration, and it also makes the gear wear in a new area that cam prematurely wear out the gear on the cam or oil pump drive.
                  I'll always be a firm believer in replacing the O-ring and nothing else added.
                  • GndPrxRcr
                    • Oct 2005
                    • 18
                    I didn't mean to confuse you but permatex makes Form-A-Gasket. we just call it permatex. even though nowadays permatex makes hand cleaner and other crap too.
                    1988 GMC K2500
                    • 854x4s15
                      • Sep 2005
                      • 24
                      Sorry didn't mean to sound nasty at you when you said permatex the first thing i though of was hand cleaner(we use it at work)
                      console shift
                      delta tool box
                      My toy
                      • GndPrxRcr
                        • Oct 2005
                        • 18
                        No Problem. I should have been more clear! no harm done.
                        1988 GMC K2500
