How would I run another ground from my battery. What gauge wire should I use and where should I hook it up to the battery. Car is a '89 GP 2.8. Thanx
Running new ground
Re: Running new ground
You may as well use 0 gauge if you're going to bother at all. It's not that hard to find...local hardware store should have it. That said, all you need to do is run it from your negative battery terminal to an unpainted part of your frame. You may have to scrape paint off and add a layer of silicone to get the desired effect without getting rust too.Originally posted by GRANDFURYHow would I run another ground from my battery. What gauge wire should I use and where should I hook it up to the battery. Car is a '89 GP 2.8. Thanx
\"I think I\'ll take this oppurtunity to remove my ears.\"
--Capt. Jean-Luc Picard
94 Grand Am GT 3100 16.4@83mph
WAI, custom exhaust, MSD Coils
I don't know that the battery is even capable of using more than 1 gauge so that should work fine. BTW, I ran one because my old ground was all cruddy, and I just crimped one of the round-hole-end-thingies (someone tell me what it's called) and then unscrewed a bolt off a fender and screwed it back on with the ground in it.Originally posted by GRANDFURYI have 1 gauge left over from my stereo so I might just use that.\"I think I\'ll take this oppurtunity to remove my ears.\"
