how to hook up rpm meter on vin M 3100??
  • gboogie99
    they still can't catch me
    • Nov 2005
    • 348
    anybody know where the hookup for this is?
    • 9183
    Do you mean a tach?
    White wire, pin C IIRC, on the ICM. Do a search for installing tach(ometer) and you'll find all the info you need.
    • Guest
      Originally posted by bszopi
      Do you mean a tach?
      Or purple/white at ICM.
      • gboogie99
        • Nov 2005
        • 348
        so there is no actual sensor on the engine for this right? I am going off what someone told me on this.
        ok, so all i gotta do is run the wiring to the icm and thats it?
        • Syn
          The Master Piece
          • Oct 2005
          • 599
          you could hook it up to one of the wires on the coil packs and get half a reading. then they got some $80 or so adapter you can buy to just hook it up to the coils and get a full reading.
          just go to the ecm
            • 9183
            What are you talking about half a reading?!?! And why would you need an adapter?
            As you can see, Pin C (white wire) out of the ICM is for the tach signal. Just like I said at the top.
            • Juglenaut
              • 1130
              The ECM does the computation from pin C it will actually only pulse 3 times a revolution there fore half the cycle. If a gauge was set up to read 3 pulse per revolution then it will read actual rpm, the ecm doubles this to create resolution.
              If you have a multimeter with a Hz setting or frequency counter you can measure the frequency and divide that by 3 to get rpm.
              Pin C would be the same as hooking a wire upto the negative side of cylinder all three coils before the switch as shown in the picture.
              I am back
              Mechanical/Service Technican
              • gboogie99
                • Nov 2005
                • 348
                sounds good, thanks
