Draining coolant
  • 95Achieva
    • 11
    Draining coolant
    My 95 Achieva with the 3100 has what resembles a plastic tab/knob where the petcock on the radiator normally is. Last time I drained the coolant I just removed the hose because the plastic thingy seemed like it wouldnt unscrew or loosen. Any tips on whether this is meant to be loosened, unscrewed, or removed to drain the coolant? Any info would be appreciated...it's plastic and I'd like some advice before I try to force it.
    Thanks
    1995 3100 Achieva
    175k miles - basically stock
    15.61 @ 88.39
  • robby1870
    Squaddoosh
    • 584
    Should just twist right off.
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
    • v6h.o.
      • 1418
      you have to twist it to unlock the drain, Then Pull the drain to open it up.
      Colin
      • 95Achieva
        • 11
        Thanks...I'll give it a twist and pull.
        1995 3100 Achieva
        15.61 @ 88.39
