fuel pump keeps running
  • Dave
    • Nov 2003
    • 222
    Hey all..
    I've got a 91 Beretta GT 3.1, Auto, Air, Tilt, Cruise, power everything.. (not sure what all info you need 'bout this problem) but this is something I can't seem to figure out at all...
    every time I shut the car off, the fuel pump keeps running, so far for the longest I've noticed of almost 10 minutes, so now I pull the fuse when I get out of the car, but rather then just doing this quick fix, I'd like some ideas as to what the actual problem may be.. any help would be awesome...
    --Thanks
    -- Dave
    Dave ... Dave.45 ... DaveFromColorado ... it\'s all me.
  • Anonymous
    Something with the ignition possibly?
    Try unpluging your battery to reset the ECM.. never maybe its acting weird worth a shot.
    • Dave
      • Nov 2003
      • 222
      Tried that one, didn't work (blah!)
      I'm ready to put in my own relay, and manual switch to control the pump.
        • 9191
        You might just need to swap the fuelpump relay. If you have a multimeter, next time you turn off the car, check to see if the relay is sticking. If its not getting a "TURN ON" signal, but the relay is still shut, then its a bad relay. If it is getting a "TURN ON" signal, then you'd have to trace the problem further back (which would lead most likely to the ECM, but without looking at the schematics, I can't be 100%).
        • RLJ
          • Nov 2003
          • 25
          Could it be a bad or leaking fuel pressure reguator on the fuel rail? Could be allowing the fuel to get past it and back down the return line, not letting the pressure build up. Or possibly simply a weak pump. I'd go rent a fuel pressure guage and see what's happening before I'd go to the trouble of modifying the control circuit. You're only treating the symptom, not the cause.
          90 Chev Lumina 3.1 398 000 KMs
          If if works, DON\'T FIX IT.
            • 9191
            Low fuel pressure won't cause the pump to continue to run after the car is off. From his initial description, it doesn't sound like the car is running poorly (which it would if there was a pressure issue), it's just that the pump continues to run after the engine is turned off. There are really only a couple things that could cause this to happen.
            • geoffinbc
              Iron Head Enthusiast
              • 5831
              The oil pressure sending unit may also be to blame. The sending unit is what provides the 12V to the pump when the car is running. Second the fuel pump relay should ONLY be on the when the ECM commands it on for 2 seconds to prime the fuel pump. So test this by turning on the key and seeing if the pump primes for 2 seconds then shuts off.
              • Dave
                • Nov 2003
                • 222
                .. well the car is running great, fuel pressure is up there (I've already got a gauage for that)
                the fuel pump does prime up at the initial hit of the key.
                there's no leaks anywhere in the system, I just replaced all my O-rings on the fuel rail because it was doing this same thing before, then I changed the oil, the problem went away, and now it's back, so I'm thinking that it is the oil pressure sending unit.
                Thank you for the help guys!
                --Dave.
                • geoffinbc
                  • 5831
                  Yea I'd suspect it too. Next time it does it remove the plug from the sending unit and see if it stops. If it does stop then the sending unit is staying closed for some reason keeping the pump on.
                  or just go ahead and replace it. Probabally 90% sure it is the problem.
                  • Dave
                    • Nov 2003
                    • 222
                    yeah, I got the new part, I'll be puttin' it in later today (tuesday) hopefully that'll fix the problem - Tonight the strangest thing happened, I shut my car off, the pump stoped like it normally should, then I went out to my car 'bout an hour later, and the pump was running, I was like "Holy S#!T!" so I pulled the fuel pump fuse and decided that I'd better wait to work on it tomorrow, rathern then getting angry at it tonight.
                    Thanks again!
                    --Dave.
                    • geoffinbc
                      • 5831
                      LOL thats funny.
                      • Chug
                        • Jan 2004
                        • 30
                        Im glad I looked at this. I have the exact problem with my 87 Cav, and I looked at the schematics and it didn't make sence but now with the explination of the oil pressure sending unit it makes perfect sence, I would have to say that is a good sugestion. I'll have to check that myself!!
                        (some of you might remember me hug311, I'm back fellas)
                        WHERE'S THE PARTY
                        (Artist Formerly known as hug311)
                        87 Cavalier Z24 Convertable
                        87 Fiero GT
                        94 Z28 LT1 Auto
                        06 Nissan Titan CC
                        • packardbell
                          • Jul 2014
                          • 91
                          my fuel pump keeps on running after shut off as well.
                          pulled the relay and pulled the oil pressure switch but the fuel pump does not go out.
                          1988 cutlass supreme 2.8
