!!!oil Leak!!!
  • scberetta3800
    • Jul 2006
    • 42
    !!!oil Leak!!!
    I recently rebuilt my 88 2.8l MPFI engine, i know that when you rebuild engines that they burn some oil. my problem is a actual leak. there is a sensor of some type (looks like a oil pressure sensor) that is mounted next to the cap where the distributor would go. it is leaking oil and is causing me to add half a quart of oil per day. what is the sensor? i have a 1989 block of the same engine, but it dosn't have a port for this sensor. is it nessesary to have? someone help me quick!
    • 9190
    http://60degreev6.com/showthread.php...p+drive+o-ring
    Post 7 will lead you to a "How-To" on v6z24.com.
    • scberetta3800
      • Jul 2006
      • 42
      no, that O-ring is not the problem, the sensor right next to it is though. like i said it looks like a oil pressure sensor, but isn't the oil pressure sensor located on the side of the block? i just need to know what the sensor is so i can replace it.
        • 9190
        I don't think I've ever seen a sensor in that area of the engine... Got a pic?
          • 9190
          Here is a picture I have of a 3100 and the oil pump drive, and there is no sensor even close to it...
          • scberetta3800
            • Jul 2006
            • 42
            right, because your engine is newer, mine was made in 1987. yours probably uses a different computer. I saw another engine at the junk yard that had the same sensor, so it wasn't just a Quick Fix or anything, also it goes right into the wiring harness.
            in your picture the sensor would be coming out of the block at an angle on the flat right next to the front cylinder head.
              • 9190
              Hence the reason I asked for a picture...
              • scberetta3800
                • Jul 2006
                • 42
                yeah, sorry i don't know how to upload or where to upload pics.
                  • 9190
                  Hit the "Post Reply" button instead of using the Quick Reply.
                  Below the msg box, there are Additional Options, and then Attach Files. Hit the "Manage Attachments" button and browse for the file, then hit upload.
                  • scberetta3800
                    • Jul 2006
                    • 42
                    well i found that the sensor is actually a switch, i bought one today and installed it, so ill have to see tomorrow is it still leaks.
                    • sharkey
                      • Jun 2004
                      • 2061
                      please, still take a pic of it and post it. im curious what this switch is. ive never heard of or seen it before, and my buddy had an 87 cavy and i have an 86 with gen 1 motor.
                      • montess408
                        • May 2006
                        • 391
                        yeah same here i have about 5 or so 88 89 90 2.8 /3.1 and i never saw that senser there
