electric pump
  • prophiseer
    Blaspheming Heretic
    • Jun 2006
    • 354
    electric pump
    Was wondering if anyone has done any research into the availability of an electric water pump or a remote electric water pump for the FWD OHV motors?
    I was considering looking into taking a water pump core and making one, I figure it shouldn't be all too hard . . . but if there's one already on the market . . .
    N-body enthusiast:
    {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
    {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
    Current Project:
    {'90 Chevrolet C1500 Sport 350TBI}
  • AaronGTR
    boost lover
    • Jan 2004
    • 708
    NA... not available. I know a few people have looked at this before. There's some threads around somewhere. Don't think anyone ever came up with a solution though. Personally, I don't think the power gain would be worth the cost or complexity. Especially with the limited room in my engine bay. It might work better for someone else though so...
    '97 Grand Prix GT 3800 (sold)
    Gotta love boost!
    • sharkey
      • Jun 2004
      • 2061
      i know moroso makes an electric water pump conversion kit. its basicly a small 12 volt motor and a belt drive to the factory water pump. this is just as good as a complete electric pump, and i know many people that have used them on various applications with no issues at all.
      • prophiseer
        Blaspheming Heretic
        • Jun 2006
        • 354
        Hmmm . . . it might be an option. I'm not all that concerned about the slight power gain, I'm looking more at trying to even the cylinder head and block temps a bit more . . . increase cooling efficiency. With the upper end I'm still slowly working on, I'm putting in a coolant crossover line on the LIM between the coolant ports aside cylinder numbers 1 & 2; It looks like I've got enough space behind the P/S pump and underneath the runners to throw in a 1/2" stainless line (from my experiences with the blown LIM gaskets, it tends to be those two coolant ports where flow just kinda stops, a lot of junk buildup that hardens and cracks the gasket).
        Anyways . . . I was looking into grabbing a wp core from the yard and removing the pump impeller and shaft, replacing the bearings and seeing if I can't find a relatively small 12v motor with a long enough shaft on it that can drive the impeller; but I'm running into the headache of figuring what kind of speed the thing will need to turn to produce at least 25gpm at full flow, and then some way to vary that speed by varying the voltage based on engine rpm. I guess if push comes to shove, I could just full field the motor and allow it to turn at speed . . . need to see if I can find a motor, though
        N-body enthusiast:
        Current Project:
        • sharkey
          • Jun 2004
          • 2061
          most electric water pumps are on race only stuff, not designed for street use. they are usualy on or off, they dont varry based on rpm.
          • prophiseer
            Blaspheming Heretic
            • Jun 2006
            • 354
            I forgot that, true (damn I feel stupid ); I gets ta thinkin and I's gets ta over complicatin!
            N-body enthusiast:
            Current Project:
            • Scott_68B
              • Nov 2003
              • 147
              Killer B v6 has been selling an electric pump set-up for our engines for quite a few years. I saw one installed at a car show a few years ago....looked good and the owner was very satisfied with it.
              -- Scott
              • prophiseer
                Blaspheming Heretic
                • Jun 2006
                • 354
                is that their homepage? $225 is kinda costly, IMO.
                N-body enthusiast:
                Current Project:
                • Scott_68B
                  • Nov 2003
                  • 147
                  Originally posted by prophiseer View Post
                  http://www.killerbv6.com/home.html
                  Yes, that's it. I don't know that I'd spend the money either but it if you're serious, it does work and he supplies everything you'll need to get it up and running.
                  -- Scott
                  • prophiseer
                    Blaspheming Heretic
                    • Jun 2006
                    • 354
                    I'll consider it, I might contact them for some more info.
                    Thanx for the info, though!
                    N-body enthusiast:
                    Current Project:
