GM's aluminum 60* engine block...
  • 85maro
    • Sep 2006
    • 140
    Anyone know how much it costs? Not that I could afford it anyway, but I like to dream...
    Oh, and I want to start a thread on it too. Anyone actually own one?
    • 9187
    There are a couple people on the forum who either currently own one or have owned on. They have been discussed on the forum many times. Current price IIRC is around $3k from GM. With a little searching, you could find plenty more info.
    • Ortie666
      • Jul 2005
      • 340
      http://www.gmpartsdirect.com/
      GM PART # 10051141
      CATEGORY: All
      PACK QTY: 1
      CORE CHARGE: $0.00
      GM LIST: $4,359.23
      OUR PRICE: $3,173.52
      Thats the 4 Bolt main aluminum block that can accept a 91mm bore
      I would also like to buy one of these blocks too.. not untill I start winning some big races tho.. its quite an investment!!, worth it tho if you have no other way to loose 50 lbs
      Six-t-Six Motorsports
      2.8L Chevette Roadcar
      3.2L Acadian Racecar
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        That and it would make installing a roller cam block in a RWD vehicle a hell of alot easier.
        I need one.
        • sharkey
          • Jun 2004
          • 2061
          im sure if your going to the extent of needing that block, you would be using a solid roller anyways.
          • 427v8
            • Jun 2006
            • 28
            do they come stock in anything??
            • Doubt_Incarnate
              I still watch ROBOTECH!
              • Jan 2005
              • 1130
              no it doesnt
              • Guest
                I have one. Brand new.
                • Ortie666
                  • Jul 2005
                  • 340
                  In what??
                  • sharkey
                    • Jun 2004
                    • 2061
                    iirc, he has a gm prototype aluminum block, heads and intake from the "porsche eater" fiero prototype. it was basicly just aluminum versions of the gen 1 iron block and heads, and i think the heads even had the small valves in em.
                    if this isnt you shaun, disregard this post.
                    • AaronGTR
                      boost lover
                      • Jan 2004
                      • 708
                      Last I heard too it wasn't installed in anything yet. Still in the crate. Don't know if that's changed or not.
                      '97 Grand Prix GT 3800 (sold)
                      Gotta love boost!
                      • Ortie666
                        • Jul 2005
                        • 340
                        EWW, puke.. a gen 1 block?? so it had the dinky little mains in it?? no wonder why it's not in anything yet..
                          • 9187
                          There is a member's photo gallery of the prototype aluminum block, NOT the actual Bow-Tie block.
                          • Guest
                            No. I have the bowtie block. Large mains, 4 bolt caps. Not the prototype block. Someone else has the prototype block and prototype heads running around in his fiero. He posts on www.realfierotech.com
                            I did at one time also have a prototype block but I sold it to someone in Arizona. he posts on here too.
                            • 85maro
                              • Sep 2006
                              • 140
                              Anyone have a guestimate on how much power you could pump through it? Seems with 4 bolt mains, extra webbing and thick cylinder liners it could hold up to alot more abuse than the iorn blocks could, although an iorn block would be much stiffer. When I get the $$ for it I'm going to use block filler on one of these, turbo it, put it on alchol and see how much I can get out of it before I break something.
