engine block filler
  • bjornmk1
    • Nov 2006
    • 266
    yeah..that's possible butt I would need to sleeve that block for the
    fitment of the forged pistons I have here.
    I am having my 3.1 block sonic measured tomorrow at work.
    after that I'll probably decide to fill her to about plugheight,that way most of the wall is supported.
    B
    nothing's impossible-it's just a mindset
    • bjornmk1
      • Nov 2006
      • 266
      tried soni measure at work butt it didn,t work.
      the probe wasn't suitable for this type of measurement.
      asked to company's if they could measure it ..but nothing..
      finally brought it to my machinist for boring to 3.57
      we will see the outcome.
      if it looks risky I will fill her up to the freeze plugs with hard blok.
      btw if I use the 2.8 crank than the actual used cilinderlength(height)
      will be lower than with the 3.1 crank.
      so this will be beneficial to the strength of the cil.wall.
      B
      • fivepointhustla
        I prefer fast & reliable
        • May 2004
        • 181
        The racing sleeves will hold more than you can throw at them. They should be made of ductile iron. Around my way it cost about $100 a sleeve. Good luck with the thin walls and boost.....
        Clean Feet Pet Clean Up
        Pet Waste Removal Omaha
        We offer dog waste removal and cat waste removal services.
        (402) 320-3824, We service the Omaha, Ne. metropolitan area.
        • Doubt_Incarnate
          I still watch ROBOTECH!
          • Jan 2005
          • 1130
          It's the "and boost" part we are worried about. An m90 is good boost for a 3.8, a full liter bigger than a 2.8, or 800cc's bigger than the 3.0 he's likely to end up after the boring.
          • bjornmk1
            • Nov 2006
            • 266
            the thing is..sleeves are not the best choice because
            the threadholes of the headbolts will only be supported at one side
            instead of 2.
            so that's a negative..
            eh..second it would be to expensive to do for me(about 450$)
            and third..the forged custom pistons would cost me a grand overhere !!!!
            standard hypereutic's aren't realy up to the job if reliability is essentiall.
            so that leaves only the option of reboring to 3.57" that;s only .070
            instead of the MAX .060 that the manufacturers use.
            I am realy considering filling her to the plugs..for some extra support,
            butt won't that give probs with cooling??
            STILL BRAINSTORMING ABOUT THE FILLER
            • fivepointhustla
              • May 2004
              • 181
              #21
              Where are you located? 450 is cheap for a motor you KNOW will take some abuse. Nobody modifies a motor for performance not to beat on it. Like they say pick 2 of these 3...Cheap, Fast, Reliable. Personally I go for Very fast and reliable.
              Gotta pay to play....Atleast that's what they say at the strip club LOL.
              • Darin
                • May 2006
                • 259
                #22
                You shouldn't notice any cooling issues filling up to the freeze plugs, We do this all the time on the 92-97 LT1 blocks, and have not had a cooling problem yet.
                But, Only going up to the freeze plugs will strengthen the lower end, and not the cylinder walls.
                1999 Grand Prix SE 3100
                1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
                1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
                  • 9187
                  #23
                  IIRC, he is over in Finland, or Norway, or somewhere over the ocean in Europe.
                  • bjornmk1
                    • Nov 2006
                    • 266
                    #24
                    I live in belgium europe
                    I wonder if it is possible to fill almost the entire
                    block with filler and create channels before filling it.
                    maybe with some kind of wax will do the trick..JUST brainstorming
                    I will have the block dye checked after boring..so that i
                    can be sure there are no cracks in the walls.
