Question about M90 intake manifolds
  • stormwolf1972
    • Oct 2006
    • 52
    #31
    oh yeah it will sell....hopefully it wont be too long length wise......dont forget us 60 degree f-body guys....that damn cowl...grrrr.......but keep us posted...i was thinking about a 4 inch rise ram air hood anyway...this would be a good excuse to get it
    • CNCguy
      Bisong eater :P
      • Dec 2003
      • 1017
      #32
      Originally posted by silvergtjrad View Post
      Has any attempt or progress been made on this yet? Just a way to mount the charger on the manifold so that it lines up with the accessory pullies. I would be willing to front some $$ assuming that it could be created in a reasonable amount of time.
      Done a little bit of the CAD work but nothing yet on machining. Been way too busy to work on it. It is not my highest priority project at this time. Several others still in front of it. I will update everyone when I make some progress.
      MinusOne - 3100 - 4T60E
      '79 MGB - LZ9 - T5
      http://www.tcemotorsports.com
      • PCGUY112887
        • Feb 2006
        • 1067
        #33
        SC's are cool but it seems that a turbo project would be easier/cheaper/no hood issues/possibility for more power without changing much?
        From a business standpoint, it seems like a set of great priced turbo headers would sell the most. Or hell even selling modified stockers that have been cleaned up/sprayed with your flange of choice could work. Offer some pre-bent IC tubing for a small IC that is made to fit in our engine bays, would be great.
        SpudFiles
        Theopia
        Enjoy life online.
        • TazMan
          • Jun 2006
          • 285
          #34
          Yeah, swap the 3500 top end on it:P Thats the best route to go anyway.
          I thought I read in a post somewhere that the 3500 heads could only be swapped to a 3400 cause the combustion chamber was to big for a 3.1/3100 or something like that? Did I misunderstand/misread something?
            Live life 3.7mi at a time
            • 4555
            #35
            +.060" bore will make them fit.
            • bjornmk1
              • Nov 2006
              • 266
              #36
              and how about the drive belt?
              would that be a 6 or 8 groove serpentine..cause if you go the 8 route
              then you would have to change all your pulleys.
              personally I would go the 8 route for less slipage.
              unless it's only gonna make about 8psi or so...then the 6 should be sufficient.
              just my 2 cents.
              bjorn
              nothing's impossible-it's just a mindset
              • AaronGTR
                boost lover
                • Jan 2004
                • 708
                #37
                I asked about the drive belt already but... you could do an 8 rib drive for the SC without changing all your other pulleys. You just have to make an adapter pulley with an 8 rib on the front for the SC and a 6 rib on the back for the stock belt and run the SC on an independent belt and tensioner. The GTP's are like that, they don't run off the same accessory belt.
                '97 Grand Prix GT 3800 (sold)
                Gotta love boost!
                • merlot566jka
                  • Nov 2006
                  • 570
                  #38
                  what ever happened to this?
                  2012 Chevy Sonic Turbo 6spd
                  • IsaacHayes
                    Mr. Orange.
                    • Apr 2006
                    • 6030
                    #39
                    I'd rather see a remote mount kit for down where the A/C was... then you can run a stock hood, and run piping to intercool...
                    • CNCguy
                      Bisong eater :P
                      • Dec 2003
                      • 1017
                      #40
                      Too many other projects and a lack of time and money.
                      '79 MGB - LZ9 - T5
                      • G-U-NOT
                        Banned
                        • Jan 2006
                        • 158
                        #41
                        I was actually thinking about starting a project like this and using the M62 thatI have laying around! I think it would sell the most for the 3.1 mpfi engines.... you know, for the guys who still have the older engines in their car and just want a good bolt on without having to do a motor swap!!
                        • mcgavinz26
                          • Dec 2004
                          • 84
                          #42
                          This would be cool, but harder than it sounds to actually produce. The 60 degree valley doesn't leave a lot of room for injectors if you cram an m62 or m90 in there. I think that the biggest problem is finding a good spot to locate the injectors after you get done burying the supercharger down low. There really isn't an easy and cheap way to do this. Also, you still need to find a spot to stick the power steering pump when you are done. And visibility really isn't a problem if you pick up a few inches in height. Whenever people sat in my car the first thing they would say was something like "huh, that doesn't really block your vision at all does it?" The hoods have a pretty good slope on them and the seats in something like a beretta or grand am sit you up higher than you realize. I was still looking down on the top of my m90 when it was installed.
                          CNCguy's got some good skills from what I can tell. If there were a way to do this that were worth it, him or someone else would have done it already. A lot of people with the right tools have talked about doing something like this.
                          1988 Fiero GT 5spd
                          1999 Regal GS
                          SOLD 2000 C5 Coupe M6
                          RIP 1994 Beretta Z26 - M90, 3400, MSV3, 5spd
                          • merlot566jka
                            • Nov 2006
                            • 570
                            #43
                            I've got a fiero with a 3500...no power steering, no hood clearance issues...... its about as simple as a manifold to me. and the injector placement isn't that hard, they can almost go anywhere, even the intake port of the head. and since its supercharged they don't really need to be aimed at the back of the valve (even tho that's the best idea)
                            I was just wondering if I could get this sparked up again, sure would like one for the 3500 fiero
                            • grandsport3.4
                              overkill customz
                              • Feb 2008
                              • 20
                              #44
                              i am very interested but i bet it wouldnt fit under my 93 firebirds cowl
                              • silvergtjrad
                                uber slow grand am
                                • Feb 2007
                                • 302
                                #45
                                You can always do it the ghetto way, like that beretta had. The plenum was machined down, and an adapter plate was made to fit the SC, then welded the plate to the plenum that was machined.
