my turboed 3.1L camaro
well in some of the pics u can see were i stared making plates/flanges that bolted to the heads,i was gonna make a sheet metal manifold out of those,but then i found the 3.1 lim from a berreta that would almost fit the distributor.after machining the back of the manifold for the dizzy to fit,i decided i didnt liek the runners in the manifold so i just started machinng them away,when im done alls that will basically be left will be the holes for the injectors with the whole middle of the manifold gone,leaving me to make my own runners and plenum.Originally posted by kflo 93 gt View PostNice work there, that's actually the first cool 3.1 RS I've come across. The new engine looks good too, what are you planning to do with the manifold?
pretty much the same thing i was gonna do with the plates but atleats now the sides the bolt to the heads and the end rails/water pasaages will all be intact in one piece,saving me alot of work down the road.
other then that its hard to explain but as i work on it ill keep posting pictures so u can see what im doingsigpic
Hey that is a great looking setup. It reminds me of my original turbo system on my Century. You've got (what appears to be) the same air / air intercooler (did come from the Volvo?) and airflow meter.
How are you going to tune the engine management system?
Can't wait to hear how it runs! Do you have a page with more technical details?David Allen - Northport, AL
crazy manifold, id like to hear how it welds once ur done, make sure to presure check it, that aluminum is shitty to weld to, but im happy someone else is choppin a 3.1 manifold, mabye one day they will make an aftermarket one..VIDEO Acadian http://videos.streetfire.net/video/8...7f00197eea.htm
Six-t-Six Motorsports
2.8L Chevette Roadcar
3.2L Acadian Racecar
yeah its a volvo 740 ic,i just ordered a large aluminum front mount for the car though since i was noticing around a 4psi preasure drop across the ic above 12 psi.(id get 18 psi at the manifold,but 22 psi at the turbo outlet.)Originally posted by davida1_hiwaay_net View PostHey that is a great looking setup. It reminds me of my original turbo system on my Century. You've got (what appears to be) the same air / air intercooler (did come from the Volvo?) and airflow meter.
belive it or not im still running my factory ecu,for the longest time i was tunning with and fmu and wideband,till i put in 30 pound iinjectors,once i hit 30 pound injectors i had a custom chip burnt.but on the new engine i am going to run megasquirt.
i have alot of info on this car at thirdgen.org/techboard/v6.sigpic
could you show more picture of the LIM and the distributor. I want to do the AL head swap too but just wanted to know what has to be done to run the dizzy. I plan on a custom intake but didn't realize the lower intake stopped to use of the dizzy. I knew the upper was problem.Clean Feet Pet Clean Up
Pet Waste Removal Omaha
We offer dog waste removal and cat waste removal services.
(402) 320-3824, We service the Omaha, Ne. metropolitan area.
not bad man should of used the 3400 top end and modded the intake you'd get a nice gain just from that.
you got a good platform as well it being rwdsigpic
