in my quest to achieve a couple hundred horse more, i want to know which 3500 has the forged crank? i found a 05 3500 for 350 and i think im gonna pick that up
which 3500s came with forged cranks?
[SIGPIC]
12.268@117... 11's to come!
http://www.youtube.com/watch?v=GUqJyopd720Tags: None
It's not dependably specific to a 3500 vehicle as we discovered earlier this year when it was thought according to GM that my two engines one from the 04 Malibu and the other from the 05 G6 had cast cranks. They both had steel cranks and this is how you tell;Originally posted by MidnightriderZ24 View Postin my quest to achieve a couple hundred horse more, i want to know which 3500 has the forged crank? i found a 05 3500 for 350 and i think im gonna pick that up
Remove the balancer bolt and look for this four digit number:7484 the last four digits in the steel crank stock number, 12577484. There is another number stamped on the end of it also but those four digits are the ones you care about. They were on both of my cranks.
The end of the crank snout is where the numbers are, not the bolt. Thought I'd mention that since it's necessary in this day and age to stamp "Not for on road use" on a wheel barrel.Last edited by Guest; 12-08-2006, 03:16 PM.
thanks, ill check it when i get it apart. my goal is a couple hundred beyond curtis's.[SIGPIC]
Yep, you should see two numbers, one is long the other is 4 digits, if you see 7484 = steel, 8259 = cast, either way these two cranks are stronger than the previous cranks thanks to the additional metal for added stiffness.Originally posted by wasas9 View PostInteresting.
Paul, those arent the 3500s in Janesville are they?
So if I understand this right, I need to remove the bolt on the harmonic balancer, and read the casting #s perpendicular to the key right?
why yes steve... ask for jeremy if u need one, i talked him into selling one DIRT cheap...Originally posted by wasas9 View PostInteresting.
So if I understand this right, I need to remove the bolt on the harmonic balancer, and read the casting #s perpendicular to the key right?[SIGPIC]
anyone have an actual part number for the forged crank from gm?? id rather buy a new one.. whats the fitment issues with the 3400 ?? anyone tried it yet?1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
The fitment issues is about an 1/8" slot where each rod end would come in contact with the block. You could grind out the spot on a 3400 block easily enough.-Brad-
So these are forged? With a bit of block clearancing and a new reluctor wheel, would they fit the DOHC? GMPD has them for $321. Thanks.
Tim1995 Z34 - T04E "60" trim, 42.5 lb/hr injectors, AEM WBO2, FFP UD&DB, 3" exhaust, 2800 stall, shift kit, tranny cooler, Powerslot, Hawk HPS, rear disc conversion, KYB, Eibach, HMS F&R STB, Fittipaldi Force 18" wheels, big stereo, lots more coming eventually...
325 whp 350 lb-ft
12577484Originally posted by timg View PostSo these are forged? With a bit of block clearancing and a new reluctor wheel, would they fit the DOHC? GMPD has them for $321. Thanks.
Tim
Double check that price, a few months ago when I was trying to sort out the cast iron or steel crank issue the $300 crank was cast and the $400 crank was steel. Another concern is that the block relief if I remember correctly because it was done for late model V8s also, is also inside the block as well as the side rails making about a 180 degree sweep, not sure if it is because it needs it or because of the method they used to relieve the block.
so grind a 1/8 inch off the 3400 block and the 3500 cranks falls right in.... same size bearing journals?1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
Yeah and then you need the external trigger to get the timing to work.
