performance cam or B...hit ?
  • bjornmk1
    • Nov 2006
    • 266
    can someone tell me if the cam in my fiero
    is a perf.cam ?
    the number on it says : 1379 or1879...the guy that sold me the car
    said there is a perf.cam in it
    thanx,B
    nothing's impossible-it's just a mindset
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    ??? Measure it. Use a dial indicator and measure the cam off of a flat surface on something like a table saw table or drill press table. You can get a good enough measurement to tell if it is stock or not. Measure the base and zero the dial indicator and then measure to the tip of the lobe.
    • bjornmk1
      • Nov 2006
      • 266
      it says GM on it so..it could be of a 3.4 v6 right.
      those cams are used as a performance cam in the 2.8/3.1 I thought.
      BTW. what do you mean by dial indicator ?
      I've never heard of it.
      oh..and happy newyear guys
      • sharkey
        • Jun 2004
        • 2061
        the 3.4l got the same cam as the 2.8ho, and thats the same cam thats in the 2.8/3.1 gen 2 motor.
        the 3.4ht crate motor got a better cam.
        • ezrollin
          • 205
          The specs on the crate cam are 427/454 216 dur/107 lsa,crane has a cam with he same specs except it has a 112 lsa. Chose depending on whether you want power mid-range or topend.
