crank mods
  • bruce farris
    • 13
    crank mods
    I need some info on lead-in groves(for all mains ?) & cross drilling #'s 2 & 3...
    also enlarging #'s 2 & 3 oil passage dia .. Gen 1..oil is everything...
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    It is in the chevy power manual. I think you can download it off this site. FYI all late model cranks have the lead in grooves. The cross drilling is still suggested for racing applications. For anything else the crossdrilling is not needed.
      • 9186
      Well, the Power Manual is copyrighted, so we can't really host it... But, I might be able to post the information relavent to the crank that you are looking for...
      • bruce farris
        • 13
        crank mods
        length of leadin groves ,exactly where,how many & what methods work for bringing up oil pressure,ie; shim, or new spring availability..
        VERY APPRECIATED
        • sharkey
          • Jun 2004
          • 2061
          bringing up oil pressure isnt a hard thing to do. i run a mellings high volume pump. some recomend against it, but with a properly built motor it should cause no issues. cold start im 75psi (bypass is supposed to be set up to 70), hot idle is 35 and above 2000rpm im 60, and thats with 10w30 mobile 1 synthetic.
          general rule of thumb says you need 10psi per 100hp. our pumps are more than up to the task.
          • geoffinbc
            • 5831
            Here is the whole thing read throught it all the info you are looking for is there.
            • bruce farris
              • 13
              crank mods
              THANKS ALL;; I'll let you know how it flies after all tweeks are in place..
              I have a full machine shop , so ideas come to life ,$ only limit final outcome:
