I have a 93 gp with a 3.1 in it i plan on doing a 5 speed swap and going with a t3/t4 turbo custom intake and ehaust manifolds.. Any suggestions on what i should do with the fuel??? Injectors, fuel pressure regulator, cam, pistons, and connecting rods.. Also since im doing a manual swap could i take those tranny cooler lines and now make them oil cooler lines??
Little project...
Compress .50/.63Turbine/.57trim and actually i justed looked it up and that is good up to 300hp and i might start off with that and if not impressed then i will take the turbo off and put a bigger one on cause i want to turbocharge my gp first to learn so i can see if i can do it without messin anything up to bad the turbocharge my 2006 saturn ion 2.2 Thanks
i have the same spec turbo on my 3400 turbo. its a perfect size for your 3.1 dont worry about that[SIGPIC]
12.268@117... 11's to come!
