question is how much will the stock bottom end hold? 15psi? 20psi? 25psi? 400whp? that's what i want to know and might have to find out the hard way.....
built bottom end
hey farmerz24 is that 3500 n/a or does it got boost ? anywayz 450-500 is very impresive01 olds shilluette 3400/4T65-E stock for now
The most I actually dynoed was 430 to the wheels at 16 psi. I did run it as high as 19 psi (probably around 480 wheel HP) with no problems.
The problem is always going to be traction and drivetrain, though. I busted a couple of trannies, several stock axles, several Driveshaft Shop Axles, so.
Is your bottom end stock z24?Clean Feet Pet Clean Up
Pet Waste Removal Omaha
We offer dog waste removal and cat waste removal services.
(402) 320-3824, We service the Omaha, Ne. metropolitan area.
327 rods won't work on a 3500 crank, the rod journals are different sized.Originally posted by rickykline View Posti might just drop in a 3500 and throw in the forged crank if it doesnt have one in it.. then 327 rods with a nice set of 8.5:1 wisecos... anyone have the specs of the 3500 crank? and rods?
with a 3500 crank you're stuck with the 5.7" rods for the 4.3 V6 then custom pistons will be needed...
The only "Stock" part is the block and crank. Crower forged rods, Ross racing forged pistons.
I think thats called traction issues...
Actually, the 12.31 run was only on 10 psi. I did attempt to run 16 psi for the track, but on launch, sheared the driver's side Driveshaft shop inner CV, so never got a run in.
yeah guys I wouldn't worry about the bottom end much. Midnight is running all stock and is breaking axles.. I'd worry about transmission. I mean there is only so far you can take these cars before trans is the limiting factor...sigpic
