does anyone have the specs of the milzy turbo cam? would it be possible to get the same specs from a regrind of my 00 3400 cam? or any where close?
milzy turbo cam specs
1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..Tags: None
Stage 1 SC is .496/.500 valve lift, 214/222 duration, 109 IC, 113 LSAOriginally posted by rickykline View Postdoes anyone have the specs of the milzy turbo cam? would it be possible to get the same specs from a regrind of my 00 3400 cam? or any where close?
Stage 2 SC is .557/.560 valve lift, 224/234 duration, 109 IC, 113 LSA
you could get a regrind for very similar specs...
those are the turbo cams? or the n/a cams?1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
so if ls6 springs bind at .560 theres no point in going with the stage 2 specs... how do you think it would perform with the stage 1 lift and the stage 2 duration?1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
Valve hitting a piston is duration issues... The only other part that may need machining to clearance the 560+ lift is the valve guide on the head, it may bottom out the seal on the retainer before it gets to full lift, resulting in a bent pushrod.Originally posted by gectek View Postyah he says that machining is ness with the stage 2 cams either NA or boosted
also its on here somewhere about lift on the valves, not only do you have to worry about the spring coil bind, but also valves hitting the piston
And Ricky, DON'T regrind your stock 00 cam, get a replacement one from bens store and submit to him what you want for a grind. they are solid rather than pressed on lobes and hollow.
the head machineing is BS, the retainer won't hit the valve guide till like .700+ lift.. maybe it's just to give a little taller install height to avoid coil bind though...Originally posted by gectek View Postyah he says that machining is ness with the stage 2 cams either NA or boosted
with the dished pistons you'd be able to run a pretty high lift... not sure of the limit there. I could find out on a 3500 though, maybe tomorrow night after work.
Remember though the whole point is for the valve to be closed when the piston is at TD, so that means if you’re hitting a valve on a piston your duration is too long and your interfering with the pistons movement.Originally posted by Superdave View Postthe head machineing is BS, the retainer won't hit the valve guide till like .700+ lift.. maybe it's just to give a little taller install height to avoid coil bind though...
Very trueOriginally posted by 3400-95-Modified View PostRemember though the whole point is for the valve to be closed when the piston is at TD, so that means if you’re hitting a valve on a piston your duration is too long and your interfering with the pistons movement.
Possibly... I'm not totally sure though.
i planned to buy a solid cam from ben..theres a place two streets over from me that does custom camshafts for alot of the hot rod guys around here so i was going to take it to them unless ben gives me a good deal on the cam and the grind..1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
