Another Custom Manifold
  • boostedrs
    • Mar 2006
    • 168
    RUFFLY MACHINED FLANGE
    PORT MATCHED FLANGES
    RADIUSED PORT INLETS
    AND SOME MORE ASSEMBLY
  • boostedrs
    • Mar 2006
    • 168
    AND A FEW MORE
    • Guest
      that thing is going to breathe like a mutha with no TB!! Heheh j/k man good work. can't wait to see new pics
      How do you plan to get hte fuel rail down in there?
      • boostedrs
        • Mar 2006
        • 168
        the stock fuel rail still fits,and its not welded together as one piece,its in 2 pieces,the runners are the stock mid section(ported of course) of the rwd iron headed manifold,it all bolts together just like stock
          Live life 3.7mi at a time
          • 4555
          What's stopping you from making a new Mid and Upper manifold?
          The injectors/fuel rail?
          Man that's a HUGE plenum with small runners, everything I have researched says that's good for boost.
            are you going to make the air flow diverted like a 3500 UIM? like put a divider at the end, and extend the TB neck into the middle of it?
            • boostedrs
              • Mar 2006
              • 168
              i could make a new mid section though to reuse the stock fuel rail the new mid section would look just like the stock section,though im sure i could improve it some,but the stock mid section isnt all that bad to begin with
              isaac - ive never seen a 3500 uim so im not exactky sure what ur refering to,im putting the throttle body on pretty much just liek it was on the stock uim
              • fivepointhustla
                I prefer fast & reliable
                • May 2004
                • 181
                Looks like a good start for a m62/m90 intake manifold.
                Clean Feet Pet Clean Up
                Pet Waste Removal Omaha
                We offer dog waste removal and cat waste removal services.
                (402) 320-3824, We service the Omaha, Ne. metropolitan area.
                • 95naSTA
                  • Jan 2005
                  • 28
                  Wow. Nice Welds.
                  95 Bonneville - RIP
                  90 Regal Custom -RIP
                  2nd 95 Bonneville (max effort L36 build)
                  98 Infiniti i30 (vq35'd)
                  • treeZ24
                    i wanna go fast!
                    • Mar 2004
                    • 251
                    great looking welds. how long you been welding aluminum?
                    too bad the port sizes are so small though lol
                    got zap-straps?
                    89 Z24
                    13.886 @ 96.16 mph
                    street trim - slicks
                    • treeZ24
                      i wanna go fast!
                      • Mar 2004
                      • 251
                      double post...
                      got zap-straps?
                      89 Z24
                      13.886 @ 96.16 mph
                        You could search for 3500, but basically where the TB bolts on, (the neck) extends inside the manifold, and stops in the center. Instead of just opening on the side. And at the very end of the intake, there is a divider so it diverts air to the sides and into the ports. Basically makes equal air flow to all cylinders as best as it can.
                        sorta like this top down view:
                        ___________{port___________________port___________ ________port}
                        TB - neck -{ (goes inside plenum and opens in center) - divider}
                        • boostedrs
                          • Mar 2006
                          • 168
                          almost finished,need to wled in the bungs for the vacum lines,and add in bungs so i can hook up my bov,wastegate,fmu to individul lines directly to the manifold instead of teeing them all off one line
                          im undecided but im either going to get this poweder coated,ceramic coated,or im just going to polish/buff it out
                            • 4555
                            I say you grind the welds smooth and polish it.
                            Or I showed you the anodizing spray I found, didn't I?
                              • 4555
                              Good idea!
