What can I do to a 3500?
  • salbers88
    • Feb 2007
    • 19
    I'm looking for stuff I could do to my LX9, I'm already planning on port&polish along with air intake and exhaust. Whats the bore of the stock throttle body and how big could I bore it out, and lastly whats the peak performance injectors I could put in it?
    Stock throttle is 65mm on a 3500 but its electric control, so you'll need a new TB anyways unless your car has a 3500 already stock.
    Headers would be nice, or at least keep the nice exhaust manifolds and re-work them to fit. You wont need bigger injectors unless your stock ones max out, and you'll need to be able to tune your computer as just swapping in new injectors will result in flooding at idle as the computer is set for the injectors it came with. Being able to tune is key.
    • salbers88
      • Feb 2007
      • 19
      3500 is stock I need to know how much i can bore out the throttle body and intake to match, or if anyone knows of any aftermarket TB with manifold
      • onefastV6
        • Sep 2005
        • 880
        What vehicle is the engine in?
        2000 Grand Am GT
        2011 Chevy Impala
        • salbers88
          • Feb 2007
          • 19
          2005 Malibu
          What kind of power increase would I be looking at if I did P&P, air intake, exhaust, and throttle body?
            I doubt you need a bigger TB, the heads allready flow TONS, the exhaust manifolds are pretty damn good too... Your best bet is to put in a cam that'll use that badass top end. For exhaust, i'd run something bigger than stock, maybe 2.75" if you can find it, a good flowing muffler as well.
            • salbers88
              • Feb 2007
              • 19
              What cam and muffler would you recommend?
              And what all have you done to your 3500, and whats the hp and ft/lbs on it now?
              • CNCguy
                Bisong eater :P
                • 1017
                The LZ9 engine also uses an electronic TB that is around 70mm. It has the same bolt pattern as the LX9 TB but I have not checked the wiring harness to see if it is the same. My guess is that it would be interchangable but it needs to be checked out to be sure.
                Also, you will want to find something to reprogram the ECM for performance upgrades.
                MinusOne - 3100 - 4T60E
                '79 MGB - LZ9 - T5
                http://www.tcemotorsports.com
                • salbers88
                  • Feb 2007
                  • 19
                  Are any more parts compatible from the LZ9 and would I have bore the intake manifold for the extra 5mm
                  • onefastV6
                    • Sep 2005
                    • 880
                    Both DHP and HPT have yet to support the LX9, I wish one of them would step up and get support for these vehicles.
                    As far as performance goes, you might want to start with the exhaust. See if you can't rework the Y pipe where the exhaust manifolds connect and then do a cat back.
                    Then go with the ported upper and lower manifolds, flow results look amazing on these manifolds.
                    If you really want to get in to performance then I would go with a cam regrind. The LX9 shares the same cam as the 3400 engine, so any 3400 grind should work.
                    2000 Grand Am GT
                    2011 Chevy Impala
                    • salbers88
                      • Feb 2007
                      • 19
                      is the LZ9 cast aluminum intake and heads too? and would the intake and heads bolt up with the LX9
                      • CNCguy
                        Bisong eater :P
                        • 1017
                        The heads and intake will not fit because the LZ9 combustion chamber is larger than the 3500 cylinder wall. The LZ engines have nice heads and intakes but they won't fit on the older engines.
                        Edit: There are some pics of the LX head gasket on a LZ head in this thread.
                        http://60degreev6.com/showthread.php?t=34223&page=4
                        '79 MGB - LZ9 - T5
                        • torq455
                          If I only had money!!!
                          • 1615
                          how bout this one?
                          :http://60degreev6.com/showthread.php?t=34223&page=6
                          Andy
                          fastest 1/8: 10.19@ 67.17
                          fastest 1/4: 16.16@ 82.70
                          • salbers88
                            • Feb 2007
                            • 19
                            ok, and if i wanted to give it VVT could i just transfer heads from the LZ4 3500 on to my lx9 or is there more involved, and now did we decide the lz9 heads would fit on the lx9 or not?
                            • CNCguy
                              Bisong eater :P
                              • 1017
                              Originally posted by torq455 View Post
                              Interesting.... I must have my posts per page set higher since mine shows it as page 4.
                              The VVT feature is built into the block. To use the VVT at the present time, you would need to use the engine and ECM from a LZ powered car. No one has done this swap that I know of.
                              I believe the LZ4 heads are the same as the LZ9 and will not fit either.
                              Exhaust, cam, porting and TB improvements would be your best bet at this time.
                              '79 MGB - LZ9 - T5
