if anyone wants forged 3500 pistons get in now
  • farmerz24
    • Feb 2004
    • 361
    k, if anyone wants pistons the batch is almost being made.
    these will be for 4.3 rods that will fit the 3500 crank. 5.7 rods, 9.0 compression with a 20 overbore.
    probably about 90 each with pin, maybe even less depending on the intrest. and im getting total seal rings.
    let me know if youa re interested.
    you probably have about 2 weeks before the piston making machine turns on.
  • Guest
    I am guessing you are adding .20 to the hieght of the piston to compensate for the shorter rod?
    • farmerz24
      • Feb 2004
      • 361
      you are guessing wrong. the pin height is going down. there is not much clearance between the crank and the bottom of the piston and if we move the rod down this should keep the piston to crank clearance the same. .20 would be nice to add to the top to help with a stronger piston but then i feel that the piston would hit the crank.
      • 93ztwo4
        • Nov 2006
        • 75
        didnt they change the pin to correct the 3400 problem
        • rickykline
          • Oct 2006
          • 345
          you know im in biatch....
          • MidnightriderZ24
            • Jan 2005
            • 699
            what 3400 problem
            [SIGPIC]
            12.268@117... 11's to come!
            • 93ztwo4
              • Nov 2006
              • 75
              the wrist pin or does that have nuthing to do with there it is located?
              • farmerz24
                • Feb 2004
                • 361
                huh?
                • Guest
                  if you plan to use a 5.7 inch rod with the same CH on the piston for a 5.9 rod, then your piston will sit .2 lower in the block.
                  What I am asking is did you take this into consideration when specing your new pistons?
                  I dont' see how adding CH will make the piston hit the crank.
                  • rickykline
                    • Oct 2006
                    • 345
                    farmer... we need to see about rushing this some... i am ready for these pistons..
