3400 valve seat removal
  • AaronGTR
    boost lover
    • Jan 2004
    • 708
    the '91 2.2L Exhaust seals will fit your heads fine. I installed them on a pair of 2002 3400 heads and a pair of 2004 3500 heads. I highly reccomend them. I'm also using the .015" copper Comp Cams shims on the 3500 heads.
    I've heard of too many people having problems with the 318 seals. I prefer my cars not to smoke.
    Any threads to link too? I haven't heard of a single person complain about the 318 seals yet. Also aren't the .015 shims from comp just flat, without the stamped center to locate the springs?
    '97 Grand Prix GT 3800 (sold)
    Gotta love boost!
    • gectek
      I Hate Nose Hair
      • Aug 2006
      • 1472
      yah thats why i like the seats that i found for the beehive springs, both the LS6/LS2 and the newer 26916/18 springs, and they come in a pack of 16 or 12, because they are designed to be used on the L3x engines and the L67 as well, and also they will fit on our heads, but im not sure on the years, and when i get them in, ill measure them and show pics
      • loner666
        • Oct 2006
        • 435
        well i went with the 318 seals..we'll see how the hold up..im use to the smoke from a bad turbo seal so i could bare as long as its not for a while but as AaronGTR said..do u have anything to back this up?? just curious
        as far as the seats..i figured it..removed them..installed the new parts and put them back on the engine..valve covers..oil pan..timing chain and cover..and finish torqueing everything and im done..hoping to start the swap this weekend
        Best 1/4mile ET - 12.9
        Best 1/4mile MPH - 111
        1997 Ford Ranger Splash
        Daily Driver
          iirc those were .060" thick... way too thick for my application. I didn't want to wait to have the spring seats cut down. I ran the flat SBC shims on my 3400 w/o problems, lots of other people are using them as well. The spring will center itself just fine.. lol
          the 318 seal problems were happening years ago, if i can find some links i'll post them later.
          • gectek
            I Hate Nose Hair
            • Aug 2006
            • 1472
            so were u just gonna let a local shop cut the seats down for you, or was that being cut into the head?
              They were going to cut the heads so that the .060" seats would sit flush...something like $10 per cut.
              • gectek
                I Hate Nose Hair
                • Aug 2006
                • 1472
                #22
                well what was the problem, too much pressure or coil bind? and also what would the pressure have been with the .060 extra on the installed height? the installed height is like 1.7 ish isnt it?
