Anyone still looking for a UD pulley?
  • torq455
    If I only had money!!!
    • 1615
    If someone is still looking for one of these, I found a site that makes them. 15% UD. seems most of the N/A pulleys make 8-10 wheel HP. http://www.aspracing.com/frame.htm
    search in street pulleys under smaller domestics. they only list for a beretta 3.1.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
  • Zero
    • 11
    Will the beretta 3.1L UD work on the Grand AM GT. It is the same liter and bascially the same motor?
      Nope, because the 3x00 motors have a 24x sensor with a sensor ring on the pulley, and without it your idle will be very erratic and set a code.
      • 3.1cutlass
        • Feb 2007
        • 101
        that pulley will work on my 91 3.1 cutlass right?
          yeah should work fine with any 3.1mpfi as they don't have the 24x sensor and ring.
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            Junk. They are not a damper and will lead to premature engine wear and failure.
            You should never trade reliability for performance.
            • whitelightnin04MC
              • Nov 2006
              • 159
              A guy on 2kmc has had his underdrive pulley on his car for 140,000 miles now. He's got no complaints at all.
              • torq455
                • 1615
                ahh yes! the damper no damper argument again. i've seen more and more people without a damper and having no problems. there is a guy that is using a non-damper UD pulley that's doing low 12's in the 1/4 (400+HP) and turns over 7000rpm. he inspects his bearings regularly and has seen no sign of any problems. i think maybe the newer cars don't need them as much as the older cars due to better material and design.
                i don't see why not. you just have to take that 24X ring out of the original pulley and put it in the 3.1 UD. i did that with my 97 lumina 3100 and all was good. i used silicone sealer and put a few center punch divits to keep the ring in place. there was a problem with the aluminum getting hot and expanding enough to allow the ring to fall out.
                Andy
                • Jbrogan
                  • Oct 2006
                  • 203
                  i have a 96 3100, OBDII can i use this pulley, it says its for 88-95??
                  1996 Beretta
                  3100 SFI TURBO
                  13.1 @ 103 mph best in the 1/4 mile
                  • torq455
                    • 1615
                    yes you can, just transfer the 24X ring from the old pully as i stated above.
                    Andy
                    • Jbrogan
                      • Oct 2006
                      • 203
                      kewl thanks
                      1996 Beretta
                      3100 SFI TURBO
                      • Jbrogan
                        • Oct 2006
                        • 203
                        do I need to buy the kit with both the udp and the alternator pulley? What do i do about the belt size?
                        1996 Beretta
                        3100 SFI TURBO
                        • wasas9
                          • Feb 2006
                          • 102
                          AFAIK, i know the underdrive pulleys for imports if not balanced or dampened will destroy the motor. I read that on the stealth's that a certain type of pulley was no good. Whereas the 60*V6 are internally balanced, I haven't seen anyone post that they screwed anything up. I believe it could lead to premature rod bearing wear causing a spin, but i'm not the 60* guru here so I'm just stating what i know.
                          • torq455
                            • 1615
                            i have just the crank pulley and used the stock belt. i was told that i would need a 1/4" shorter belt. that was so tight i couldn't get it on. haven't had any probs with the stocker.
                            Andy
                            • Jbrogan
                              • Oct 2006
                              • 203
                              Alright
                              1996 Beretta
                              3100 SFI TURBO
