getting my headers soon. wondering
  • geldartb
    The Situation
    • May 2004
    • 1994
    do i need to buy header bolts or can i use the stock setup.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
  • whitelightnin04MC
    • Nov 2006
    • 159
    I just bought some stage 8 locking header bolts. I think it'll make the install easier. I'll let you know in a couple of weeks.
    • gectek
      Banned
      • Aug 2006
      • 1472
      u can use the stock header bolts yes if you are keeping the 3400 in ur GA...but you will want to soak them good with penetrating oil and make sure to turn them out slowly. then use a wrench if you can and a socket, a wrench to fit the nut and a socket to fit the stud. then make sure u turn them slowly. you can reuse them, but it is cheaper ins to just either get new studs and nuts(since they are compression style lock nuts) or some header bolts
      i have just put these headers on my GA, so if you want any info let me know
      • silvergtjrad
        uber slow grand am
        • Feb 2007
        • 302
        I just used the same bolts on my header install. I had one hell of a good time getting the headers and gasket to stay in place while attempting to thread the bolts in. For ease of install I think the studs would be best. However once you get the locking tabs on the bolts, they arent going to loosen up. I I had a clearance issue with the top bolt on cylinder 6. I had to grind away at the head of the bolt to get it to line up straight with the hole. Not sure if there would be any issues with studs. Hope that helps!
          I used 3400 plenum bolts with loctite on my headers.. they weren't in for that long but they never came loose..
          • gectek
            Banned
            • Aug 2006
            • 1472
            i had no issues with the studs at all, just making sure that you get the fitment right, with either putting the stud in bare or with the nut on a little, but once u know what the clearance is, then it is alot easier. also a short 12 or 13(dont remember what stock nut size is) will come in handy as well as a long one
            • onefastV6
              • Sep 2005
              • 880
              I used Breslin bolts on mine, and they worked great.
              *Apparently Breslin has gone out of business... too bad because they had a good product.
              2000 Grand Am GT
              2011 Chevy Impala
              • Guest
                I've used the stock genIII manifold studs on mine, no issues.
                • treeZ24
                  i wanna go fast!
                  • Mar 2004
                  • 251
                  i went and found some stainless hex head bolts, seem to work fine here (bit of antiseeze)
                  got zap-straps?
                  89 Z24
                  13.886 @ 96.16 mph
                  street trim - slicks
