3500 lower intake mani question
  • Jawz
    • May 2013
    • 14
    I was thinking about doing the same swap also, but cant find the lower intake mani and the heads. What vehicle can you pull them off of? since i know there a direct fit.
      Right on Wiki... Use the web guys....
      LX9
      The LX9 3500 is an OHV engine based on the 3400 V6. It incorporates electronic throttle control. Bore is 94 mm (3.7 in), stroke is 84 mm (3.3 in) for a displacement of 3498 cc (213 cu in). A GM Press Release for the 2004 Malibu described the 3500 thus: "3.5-liter V-6, will debut in the 2004 Chevrolet Malibu. The engine offers improved performance and fuel efficiency, and runs smoother and quieter than earlier generation V-6 engines. The 3500 V-6 features an advanced powertrain control module, improved fuel injection system, a redesigned exhaust manifold and a new catalytic converter contribute to reduced emissions, as well as improved efficiency and performance characteristics. Improvements in cooling, sealing and the accessory drive system add to the engine's overall quality, reliability and durability." Power output ranges from 196 hp (146 kW) to 201 hp (150 kW), torque ranges from 213 lb·ft (289 N·m) to 221 lb·ft (300 N·m).
      It was used in the following vehicles and model years:
      2005–2006 Buick Terraza/Chevrolet Uplander/Pontiac Montana/Saturn Relay
      2004–2006 Chevrolet Malibu/Chevrolet Malibu Maxx
      2005–2006 Pontiac G6 Sedan / Coupe
      2006–2007 Buick Rendezvous
      2006 Pontiac G6 GT Convertible
