balancing/weighing pistons
  • bjornmk1
    • Nov 2006
    • 266
    how close should the piston weight be
    for a performance rebuilt (+-6500rpm)?
    found that there is as much as 5 grams(european)differance.
    gr.bjorn
    nothing's impossible-it's just a mindset
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    I know builders go 2 grams or better. I would try for that. It is just a matter of a file and some patience
    • bjornmk1
      • Nov 2006
      • 266
      okay,
      the first set of 4 that i checked were within 2 grams...but those other 2 pistons are from another set of 4(cosworth 4 banger) and had about a 5 gram differance in comparisson with the first four.
      thanx,bjorn
      • sharkey
        • Jun 2004
        • 2061
        my balancing guy does everything to 0.3 grams or better. it may be overkill, but i deffinitly have a smooth running motor. this guy does the stuff for the alcohol dragster i work on.
        • geoffinbc
          • 5831
          Yea like I said it just takes time. You can zero them all if you want. But then you must be very confident in the accuracy of your scale.
          • bjornmk1
            • Nov 2006
            • 266
            I personally think it's overkill for an engine
            that only revs to about 6500rpm.max.
            just my 2cts.
            bjorn
