my 3500Z
    my 3500Z
    fired up and ran this morning for the first time... Open Headers
    Here are all the specs...
    2004 LX9 3500
    678 miles on bottom end
    Ported 3500 Plenum
    TCE 65mm TB
    TCE 65mm TB adapter
    Full race ported & polished heads
    Mirror polished combustion chambers
    Port matched and polished LIM, 800 grit polished intake tracks.
    Deburred and smoothed injector holes
    .045" Compressed headgaskets, 10.5:1 Compression
    Custom ground cam
    .539/.549, 288/293 advertised duration
    Comp Cams 26915 LS6 Springs
    Comp Cams .015 copper shims
    Comp hardened steel LS6 retainers
    Comp hardened steel LS6 7 degree locks
    '91 2.2L exhaust seals
    Stock forged steel crank
    Stock forged-Powdered steel rods
    Stock pistons
    FFP Underdrive pully
    TCE External crank trigger
    Polished 3400 fuel rail
    #36 GMC Typhoon Injectors
    350 TPI fuel pump
    2002 3400 FPR (55 PSI)
    1 5/8" longtube headers, 32" length Over the tranny
    Single 3" Exhaust, with Hooker Aerochamber muffler
    180F Thermostat
    Heated o2 sensor
    Custom coolant lines
    TB Heater bypassed
    Heater core bypassed
    Coolant fan override switch
    All A/C components removed
    Cruse Controll removed
    Poly mounts( Front and tranny)
    Solid mounts (rear)
    Transmition
    Stage 3 clutch from EZ-Clutch
    OEM flywheel
    '91 HM282 (Muncie) Bellhousing
    '93 3XTX W41 Muncie tranny
    Team GREEN 900LB LSD Insert
    Gearing:
    1st 3.50
    2nd 2.05
    3rd 1.38
    4th 1.03
    5th 0.81
    Axle 3.94
  • Guest
    I think you have too much injector, but as long as you can tune them back to where its not flooding the motor then you of course will be fine.
    • Joseph Upson
      Good job, but can you do a shorter video at a higher quality? The optimizing has really taken its toll on the sound quality of the engine, it sounds like there is a knocking noise up near the engine.
      • Scott_68B
        • Nov 2003
        • 147
        Great work, looks like it could be a beast. What ECU are you using?
          the knocking sound was the header leaking at the head, that's fixed now.
          I'm running a stock '7730 with a chip adjusted to run my #36 injectors. I'll be doing LOTS of tuning after i get the exhaust built and installed
          I'll have a better vid tomorrow, i tried to get one tonight but the damn thing is too loud.. and my neighbors looked pissed
          • torq455
            If I only had money!!!
            • 1615
            Yo Dave, what's the duration @.050 on that thumper?
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
              here is the cam card...
              Dave
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                No heater? I guess it is a summer only car LOL.
                • RedBird
                  Aka Mr. 5th Motor
                  • Sep 2006
                  • 426
                  i wouldn't want to attempt to try and drive that thing in the snow. hell, 5 speed 3400 swaps are a bitch in the rain lmao.... and this thing is WAY built!
                  Next vid needs to be of it moving, Dave...
                  Cammed 3400 --> 224whp 210wtq
                  Cammed 3500 --> ???
                  1 of 5 3500 J-Bodies
                    here is a distant clip after i installed the muffler.. there is no tailpipe after it so it's still pretty loud...
                    • torq455
                      • 1615
                      what rpm is that thing idling at? almost sounds like it's pretty lopey.
                      Andy
                        IIRC he has it down to 1000rpm now.
                          that's with most of the exhaust hooked up idling at around 1K RPM.
                          MAP is averaging .75, Moonwell says that's around 7.4 hg of vacuum. I'm gonna go buy a vacuum gauge and find out for sure..
                          It's almost ready to take for a drive.. just need to finish up the exhaust and install new sway bar bushings.
                          • RedBird
                            Aka Mr. 5th Motor
                            • Sep 2006
                            • 426
                            Haha. those bushings were slightly shot....
                            and f' the neighbors. if they can do that, you can drive your damn car up and down the street open headers at least once :P
                            Cammed 3500 --> ???
                              lol, 7.4hg of vacuum. I've got a pretty cool "turbopac" vacuum gauge I got for like 12 shipped on ebay brand new. It does a half sweep from 20" to 0" and past that it can go to 4.9 psi of boost.
                              EDIT: This one I have. I think the industrial liquidators is the place I got it from. They were selling them individually for a while I think. Might of been someone else though that had a bunch for sale.
