building destroked 3400
  • bjornmk1
    • Nov 2006
    • 266
    #46
    hey forced firebird.
    I misunderstood your question about the gasket.
    the brown circle you see is from the factory gasket.
    the engine had only 18 miles on it when it had a wrist pinn stuck....
    nothing's impossible-it's just a mindset
      Live life 3.7mi at a time
      • 4555
      #47
      No, I was asking about the ports .
      Maybe I'm a little lost, but if you are using a 2.8 crank and 3400 pistons, wouldn't the pistons be really far down in the bore if you used 5.7" rods? The 2.8 had the wristpin location .3" lower in the piston so the same rods could be used in the 3.1 and 2.8 with a longer stroke. This would mean you needed 6" rods to get the piston back at the top of the bore at TDC.
      • bjornmk1
        • Nov 2006
        • 266
        #48
        You're right about that.
        I planned on using the ford cosworth pistons that I had.
        that would work fine with that 2.8L crank.
        BUTT....since I bought these puppy's for some few $$$
        I changed my mind and wanna go the 3400 way.
        I am talking to a guy from arias to find out more on those
        pistons and they seemed to be made for NA using 200hp nitrous.
        according to beeri(arias contact) the pinn's are to thin on wallthickness.
        however the upper part(above the top ring)is beefier than a standard piston
        so I plan on removing some material there to get towards 9:1 compression.
        we'll see if I can get some pinns from arias or elsewhere.
        info on this would be apreciated !!
        Bjorn
        • bjornmk1
          • Nov 2006
          • 266
          #49
          BTW you can watch all pics on my build on photobucket
          under futurefiero.
          I now have to decide wether to go with a 3400-3.1 crank or with 6"rods.
          • bjornmk1
            • Nov 2006
            • 266
            #50
            arias has the pins I need for those forged puppy's
            they are 19$ a piece.
            think I'll go with that.
            • bjornmk1
              • Nov 2006
              • 266
              #51
              in order to get a CR of 8.6 I will need to:
              have the block and heads shaved .105 in total.
              I checked the threadholes in the block for depth so the headbolts
              will still fit properly.
              .100 on the block itself is not wise so I will have about .037 shaved from the heads and about .068 from the block itself.
                #52
                Will that work or is that too much for the heads? What about the intake manifold lineing up? Sounds like a head ache!
                • bjornmk1
                  • Nov 2006
                  • 266
                  #53
                  well isaac,
                  it looks like the heads would take .05 max or so without warping I guess.
                  I'm not so sure on the block though...but it's iron and no aloy...
                    iirc .020" is max for the heads.. any more than that is really risky
                    • bjornmk1
                      • Nov 2006
                      • 266
                      #55
                      sure ...according to the GM manual.
                      but I think that's only cause of the fitment issue of the intake.
                      I think the heads can take more than .020
                      • bjornmk1
                        • Nov 2006
                        • 266
                        #56
                        to the shop
                        tomorrow I'm gonna take the block
                        to my machinist for machining the decks
                        and have hin put a sleeve in cylindr nr.5
                        (where UNFORTUNATLY the pistonpin got stuck)
                        and if I have some sparetime this week...
                        I'll flow my other head and replace the valvespring
                        with the ls6 ones.
                        I'm also leaning towards using the mls headgaskets from the shop here.
                        they will probably do a better job sealing the heads than
                        the severe duty fellpro gaskets.
                        Gotta check my budget
                          • 4555
                          #57
                          The MLS gaskets are re-usable, aren't they?
                          • bjornmk1
                            • Nov 2006
                            • 266
                            #58
                            I wouldn't re-use them.
                            the sealing between the layers will be gone.
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              #59
                              IIRC I'm pretty sure you can buy that sealant to reapply it as necessary.
                              http://www.scegaskets.com/products/titan.html They are the ones with the sealant I speak of.
                              • bjornmk1
                                • Nov 2006
                                • 266
                                #60
                                maybe you can do that.
                                but those type of gaskets are ussually layers that are riveted together
                                one way or the other.
                                so one should seperate and clean each layer.
                                I would buy new ones for sure.
                                just my 2 cts.
