Finally doing headers
    For reference I'm doing headers from a GA in my L-body
    The Boringness....
    The hotness
    Only fitting them, not done yet...
    Sitting on the table
    It took me all night to get the manifolds out so all I did so far was test fit the front and see if there were any clearance problems. Only one I found was the dipstick needs to be tweaked to fit past the flange. Coolant heater core pipe should clear if properly attached to throttle body with bracket, so I need to replace mine, or just bend it.
    Still need to pull my downpipe out and then test fit the rear and see how much needs to be notched out to allow the header to bend down and clear the firewall... I'm hoping it wont be too much, and from the TOG header fit pics I saw it doesn't look like it was much that needed to be removed.
    So far, One broken manifold stud on the front... I really dont care because once fitted it only needs to last like 2 weeks before the whole motor is coming out.
    So what do you guys think I should see from this upgrade? 10? 20?
  • Rhedalert
    Dr. Feelgood
    • 1574
    nice, hopefully your rear header lines up and is away from the firewall. Since those are designed for an N-body, maybe you'll be ok?
    Brian
    3400 SFI V6, 4T60e
      No he will still have to mod the heck out of the rear, the L body needs like a 45degree angle, the N body is more like straight out 65* or something.
      I say you'll get -14 hp from it. haha. Ok maybe not -14 but 14. But which engine are we talking about here? Not as good as long tubes, but sure will help that 3500 breathe better.
      BTW get rid of that ugly engine cover. Looks like a playskool toy got melted on top of the motor! haha
      • whitelightnin04MC
        • Nov 2006
        • 159
        Hey those kinda look like these:
        I've got a w-body. The S&S headers fit great. I got them 2nd hand for really cheap.
        • bjornmk1
          • Nov 2006
          • 266
          sure looks good.
          where can one buy those headers ??
          keep up the good work.
          B
          nothing's impossible-it's just a mindset
            Did you cut your front flange to fit the stock gaskets and the oil dipstick??
            Mine goes right in the way of the dipstick and wont fit the gaskets because the whole flange is flat... and all ports are connected. See pic....
            But yes I already modified the rear and it fits... did about a 1/4" notch and bent the flange and it mates up fine now. Now I just need to hack up the 2-1 collector to angle the flange better....
            This will be on both motors, fitted to this one and then installed on the hybrid when its in... I figure I would get these in before that motor because its going to need them.
            This is not a job for the faint hearted... Hacking up a $500 investment is tough...
            bjornmk1 I got them from SSHeaders.com $514 IIRC
            • 86euro
              • Dec 2006
              • 214
              Hmm, looks like those would work in an A-body. Maybe even without cutting.
              • torq455
                If I only had money!!!
                • 1615
                some people say that with supporting mods: TB, exhaust, tune, and cam the headers will add ~19hp.
                Andy
                fastest 1/8: 10.19@ 67.17
                fastest 1/4: 16.16@ 82.70
                  i'd say 20 HP on a stock engine.. with a cam and port work it'll help out alot more.
                    well the cam and ported motor will come after these are fitted...
                    As of right now I have fully modified the rear header so it can bolt to the motor and clear the firewall... I just need to hack off the end of the collector and start the bend right there, and then put the flang back on once is level... That will help with clearance on the sway bar. Then I just need to mate the cross over, I will be tweaking the front part since the rear cross over part is all tight together and I cant cut or weld it back together due to clearance problems.
                    I also need to clean up the inside of one of the primaries and then it should be good to go... I hope.
                    There are some close items back there and I think I need to either sheild them or move them so they are not so close.
                      yah, make sure you keep wires and stuff as far away as possible.. i had some wire loom melting and dripping plastic on the ground with mine last Saturday.
                      I ended up rewiring like 75% of the engine bay to keep stuff away from the headers, we'll see how that works out.
                      • sil
                        4T60-E killa
                        • Nov 2004
                        • 723
                        you guys should really wrap those badboys up :P
                        http://cgi.ebay.com/ebaymotors/Fiber...QQcmdZViewItem
                        • whitelightnin04MC
                          • Nov 2006
                          • 159
                          No cutting the flange here. I took tubing benders and bent the diptube outward. Then I just snaked it around the flange. I payed 400 for the ceramic coated headers w/ catted DP. The whole install took me about 10 hours. And i wasn't really rushing through it. That includes some welding and changing the plugs and wires.
                          • torq455
                            • 1615
                            not bad at all!--the wrap i mean.
                            Andy
                            • whitelightnin04MC
                              • Nov 2006
                              • 159
                              I haven't wrapped mine, I don't plan to take them off for any reason, unless I do heads and a cam. Nothing is close to the headers that I could see. I made sure everything was good and out of the way. Also, I haven't noticed a difference in temps or anything like that. The engine bay itself gets warm a little faster, but that's about it.
