ported mass air flow sensor
  • ProjectMM
    • Mar 2004
    • 170
    Well today i took out the Granatelli mass out and put back the factory (AC Delco) sensor back in. it fixed my bad idle issues and carpy gas mileage. But as i took it out I swapped the larger cones, and put them on the factory MAF. Now it pulls a check engine light. (System running lean) but the MAF on the scanner seems to be reading through the RPM, with a good reading.
    Ported = 2.5 – 3 GPS
    Factory (stock) 4.2 - 5 GPS
    My question is there a way to get the computer to see the 4.2 GPS in the ported MAF?
    2002 Pontiac GrandAm GT1
    3400 v6
    TOG headers
    RSM 62MM T-body
    FFP underdrive pulley
    GRANATELLI MAF
    Ported upper intake
    MSD DIS 4 ignition box
    MSD Wires and coils (pending)
    Venom high flow fuel pump (pending)
  • sprucegagt
    Old School KI
    • May 2005
    • 703
    You can't swap to larger adapters on the stock MAF without ruining it's accuracy. That's why the SES light is on. The larger adapters change the airflow over the MAF elements versus the stock adapters. Put the stock adapters back on and clear the code. Your problem should go away.
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
