ITS ALIVE stage 1 Hybrid.
    Thats right
    Here is the pics and vid... Vid link at end of second post.
    Got Lope 4.0 Mb Mpeg movie
      Dammit!
      where did you find a 3 wire with the right size threads?
      Nice BTW
      • treeZ24
        i wanna go fast!
        • Mar 2004
        • 251
        i like that bluish gray damm sounds good too!
        got zap-straps?
        89 Z24
        13.886 @ 96.16 mph
        street trim - slicks
        • Nightingale
          • Apr 2005
          • 259
          She sounds mean... Any video of some engine revs?
          98 camaro swapping in lz9 th400 setup
          LZ9 specs: (Subject to Change work in progress)
          4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
            Live life 3.7mi at a time
            • 4555
            Looks and sounds fantastic! Nice clean job too .
            • Azrael
              Accelerating uphill in OD
              • Apr 2005
              • 763
              Nice work! Did you remove the fan to replace it with an aftermarket one or was it just in the way?
              1995 Grand Am SE
              • AaronGTR
                boost lover
                • Jan 2004
                • 708
                Nice. Sounds pretty mean. Good to see it's running finally.
                '97 Grand Prix GT 3800 (sold)
                Gotta love boost!
                • torq455
                  If I only had money!!!
                  • 1615
                  besides headers, what exhaust set up do you have? nice to see a built 3x00 with an auto for a change. specs on your cam?
                  Andy
                  fastest 1/8: 10.19@ 67.17
                  fastest 1/4: 16.16@ 82.70
                    Coolant temp sensor was a custom job per my machine shop
                    Cam is a Milzy Stage 1 I think... Thats what it was sold to me as.
                    Cam Specs:
                    Stage 1 NA - .305/.308 lobe lift (.488/.493 valvelift),
                    209.4/213.1 duration,
                    110 LSA, 108 IC
                    Exhaust is S&S headers, hollow cat, Moroso Spiral muffler, Shitty 2 1/4 press bent rusted out intermediate pipe, and a flowmaster 80 series.
                    Fan was just in the way, its impossible to remove the front header with the fan in place.
                    I'll get some more vids once I get it tuned. Still have some other things to finish up.
                      did you check the grind number on the cam before you put it in?
                      that's pretty healthy for a stage 1 cam... lol
                        Yeah I checked and it had the duration numbers written on it 209 and 213, so I figured it was right... I guess he has been known for miss labeling though... however if it was any higher of a lift I would have already had issues with coil bind, but I don't... Only thing I can think of is the duration is a little more than what it says it is.
                          Either way... sounds damn good!
                          I proved the duration theroy with mine.. these engines LOVE it!
                            You could get some HP freed up with a different muffler setup I bet. The spiral muffler probably isn't the best for turbulence and restriction, and I know the flow master isn't either. And your hollow cat isn't either unless you have a pipe going through it to keep the velocity the same. I'm running an ultraflo with no resonator (felt hp increase when I removed it actually) and stock pipe and cat and its an improvement you can feel.
                            The ultraflo is quiet at cruising if you have a tail pipe and tips on after it (mine fell off for a short while hah) and has a nice rumble/burble. I bet without the cat and bigger piping it would sound real nice and perfect volume. Mine is pretty short (about 1/3 shorter than the stock muffler) but if you wanted quieter get the longer model. The only restriction of flow in my exhaust is the stock cat and the 2" piping/downpipe. You can get the ultraflo in cross flow too so you can keep your duals. Got any pics of how the muffler is attached? I want dual Z26 tips
                            BTW I didn't know you dyed your interior. How is that dye holding up on scratches on the doors and stuff from passengers/etc?
                            What gauges are you running in the pillar?
                            Are those tie rods painted? Looks anodized like your old throttle body (was that paint?)
                              Holy questions...
                              Tierods are painted just like the old TB was, two stage fake anodize paint.
                              The interior is duplicolor vinyl paint, and it holds up just about as good as any other vinyl paint... Scratches if you hit it in quite few areas but still looks decent.
                              Pillar gagues are A/F and Vac (just for looks) BTW I'm only getting 15-13in/lbs now when I was getting 19 before the cam.
                              Also yes I know the exhaust sucks, It's getting treatment soon, since its rusted out over the axle, but it will be 2 1/2 high flow cat, straight back to the flowmaster 80... I know flowmaster isnt the best for flow but I like the way its setup and I think if I swap mufflers now its gonna be a pain in the arse to get a new pipe made, but we'll see, I'm not fully decided yet.
                              I think I mustered another 2 tenths at the strip once I went open header... My best was a 15.2 with the exhaust and I got a 15.07 with the open headers.
